OIL Light??
- oxcadillacxo
OIL Light??
27 Jul 2009 23:04
I just bought this kz650 for 100 bucks it runs on 2 cylinders i think it jus a ignition problem but anyway i cant get my oil light to go off i have let it sit there and run and everything seems good plenty of new oil in bike no nocking or pecking could the 2 cylinders that are not fireing be causing this oil light problem, or do you think oil pump is bad ??
78 Kz650 Sr
- donthekawguy
Re: OIL Light??
28 Jul 2009 06:07
Is the sensor wire plugged in? They loosen up and fall off sometimes.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- oxcadillacxo
- rstnick
Re: OIL Light??
28 Jul 2009 08:18
Welcome.
The oil pressure sensor is below and behind the points/elec ign. plate.
There should be a blue/red wire going to the sensor, and sometimes this wire will touch the engine or the points plate, turning the oil light on.
I've had to wrap the wire on my 650 with electrical tape because it was touching metal also.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- KawiConvert
Re: OIL Light??
28 Jul 2009 09:44
It connects at the back of the engine along with the green and black wire for the coils. Clean and check your connections. The light should go off while just cranking the bike over with the starter.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- loudhvx
Re: OIL Light??
28 Jul 2009 10:07
I've only seen them under the points plate for the 650's. Like Rstnick said, sometimes the wire gets pinched and shorts out under the points cover and that causes the light to stay on. Since you've been working in that area, it's highly likely that is the problem. It's the blue wire.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- oxcadillacxo
Re: OIL Light??
28 Jul 2009 11:00
under my point plate all i have is a little clear with red top silinod looking thing with a green wire that goes to another green wire no blue or pink
78 Kz650 Sr
- oxcadillacxo
Re: OIL Light??
28 Jul 2009 22:09
ok eveything is good !!! thanks for all the help !!
78 Kz650 Sr
- rstnick
Re: OIL Light??
29 Jul 2009 06:05under my point plate all i have is a little clear with red top silinod looking thing with a green wire
That is the oil pressure sensor.
It usually has the blue wire, but depending on your model/year of 650.
What model and year 650 do you have?
Post up some pictures as well.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
