- Thank you received: 16
Ballast resistor?
- KZ250LTD
27 Jul 2009 09:32 #309590
by KZ250LTD
79 KZ1000ST
Past:
Many.
Ballast resistor? was created by KZ250LTD
I bought some new dyna dual output 3.0 Ohm coils from Z1E a little while ago and in the description it says "For some Kawasaki bikes with a resistor in the circuit (KZ1000 79 & 80), the 3 ohm coil is the best choice - just remove the ballast resistor from the circuit.". Just wondering where the ballast resistor would be found? I'm not sure what I'm looking for :laugh:
Oh, the coils are for the 79 KZ1000st
79 KZ1000ST
Past:
Many.
- loudhvx
- Thank you received: 1616
27 Jul 2009 09:53 - 27 Jul 2009 09:54 #309603
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Ballast resistor?
Don't know where it is, but maybe the parts diagram can give a clue.
# 19 is a "resistor" in the parts list.
1981 KZ550 D1 gpz.
Other links.
Last edit: 27 Jul 2009 09:54 by loudhvx.
- bountyhunter
- Thank you received: 337
27 Jul 2009 14:16 #309669
by bountyhunter
- roy-b-boy-b
- Thank you received: 103
27 Jul 2009 18:47 #309754
by roy-b-boy-b
Replied by roy-b-boy-b on topic Ballast resistor?
The mount of the resistor are bent downward and fit between the two foward coil fasteners.(bolts) Roy
- KZ250LTD
28 Jul 2009 00:26 #309802
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic Ballast resistor?
Thanks, shoulda checked my parts diagram first
79 KZ1000ST
Past:
Many.
