Converting From Seperate R/R to Single Unit?
- TommyLeTucker22
- Two Wheels and A Passion
26 Jul 2009 01:29 #309356
by TommyLeTucker22
1981 KZ650CSR w/ 1979 KZ650 Engine
1977 KZ750 Bobber
Converting From Seperate R/R to Single Unit? was created by TommyLeTucker22
On my 1977 KZ 750 B Twin, the regulator and rectifier are separate units. Has anyone had any experience converting this set up to the six wire (or seven wire, I can't remember) like that of a later 750 or 650. Any input is greatly appreciated.
Thanks,
CMP
Thanks,
CMP
1977 KZ750 Bobber
- Lukes6
26 Jul 2009 05:13 #309359
by Lukes6
[img size=150][ home.iprimus.com.au/lbwillsmore/thumbnail.jpg/img ]
Replied by Lukes6 on topic Converting From Seperate R/R to Single Unit?
Would love to offer some advice but i am trying to solve the same problem at the moment. Will be pretty keen to see what others have done. All the best.
- Thank you received: 2098
26 Jul 2009 08:47 #309389
by Patton
Replied by Patton on topic Converting From Seperate R/R to Single Unit?
- OKC_Kent
29 Jul 2009 11:53 #310124
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Converting From Seperate R/R to Single Unit?
I do not think it can be done, if anyone knows it's this guy.
www.oregonmotorcycleparts.com/
Oklahoma City, OK
- loudhvx
- Thank you received: 1616
29 Jul 2009 17:21 #310183
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Converting From Seperate R/R to Single Unit?
Like OKC says, yours may not have a combo unit available. I would try the link he provided.
You have an excited field type alternator. That is only used on the 77 650, some 400 twins and some 750 twins. I have not seen a combo unit for those bikes.
Most KZ's use permanent magnet alternators. They can convert to combo units (if they didn't already come that way).
1981 KZ550 D1 gpz.
Other links.
