Barn Find 1978 KZ200 is fighting with me!
- deezil
What about that 4.8 universal Motorcycle coil?
Would I Need the Resistors with that coil?
- Motor Head
- Thank you received: 391
- deezil
Free too! I like Free!
It is a Pertronix car coil.
Here is a link to the one like my Buddy just brought over.
www.carshopinc.com/product_info.php/products_id/54/40511
Should I wire in A Ballast resister or anything else if I use this coil?
- Motor Head
- deezil
The Coil link is for a Pertronix 3ohm car coil. It doesnt state wether or not you have to use a Ballist with it.
I hate like heck burn up the points. It seems like they are even harder to find than the stock coil or caliper
- loudhvx
- Thank you received: 1616
There is a way to make the points last basically forever:Just Any Ballast resistor with my current AMC coil? I see plenty of 1.5 and lower ohm rated resitors but no specific 3ohm rated ballist?
www.geocities.com/loudgpz/GPZheiModForPoints.html
But you still need a resistor to limit the current in your application. (Because motorcycles have much more dwell time than cars.)
Ballasts are different from resistors. The purpose of a ballast is to heat up with usage and increase resistance as it heats up. If you can get a 1.5 ohm, 100watt ballast, it may heat up to 2 or 3 ohms, but it's hard to guess.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- loudhvx
looks Like I found a 3ohm specific coil.
If that coil really is 3 ohms, it should work ok. It'll reduce the life of the points, but won't burn them out right away (without a resistor).
If you want to be safe, you can use a 1 ohm, 20 watt resistor.
Here's a 1-ohm, 50 watt cheap. It may take time to get it, but you can use that 3-ohm coil without it for a few days.
Or if you use the 3-ohm coil with the HEI module, you won't need a resistor at all, and the points will out last the bike.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
home.comcast.net/~loudgpz/KawKZ200Man.pdf
1981 KZ550 D1 gpz.
Other links.
- deezil
Also, Thank you very much for the service manual link. I will for sure download it when I get home.
www.oldbikebarn.com/Universal-12-Volt-Ig...bh0Te34Pa38Ta38Och50
- loudhvx
If the Bike is for sure to have a 4.2 ohm coil can I get away with using this 4.8 coil without any resitors at all?
Absolutely. No resistors needed if you go up in resistance.
My friend used some coils that looked like those. They didn't really last very long, but they did work for awhile.
1981 KZ550 D1 gpz.
Other links.
