stators for "P" scoots
- mraaaaaaaaaa
22 Jul 2009 06:22
1989 KZ 1000 P
Will a stator from a yamaha 1999 R6 work ?
TY
TY
Re: stators for "P" scoots
22 Jul 2009 08:02
IF the diameter is exactly the same, and IF the thickness is exactly the same, and IF the mounting flange and holes are exactly the same, then it MIGHT work. The rubber plug will need to be changed and the plug for the wiring will need to be changed. Also, these early R6 stators seem to have a reputation for failure, which my explain why Yamaha redesigned them in 2003 and again in 2006.
Why not just use the proper one and be done with it? New and used ones are readily available from Kawasaki, aftermarket companies and elsewhere.
- Buda
22 Jul 2009 08:41
No eBay APP ID and/or Cert ID defined in Kunena configurationI dont know if it is a good deal or not but here it is.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- MFolks
22 Jul 2009 08:46
www.electrosport.com
would be my first choice for a replacement stator. Their's are overwound to produce charging current at lower rpm's than the stock ones.
A list of stator and regulator/rectifier suppliers:
1. www.regulatorrectifier.com
2. www.electrosport.com
3. www.rmstator.com
4. www.customrewind.com
5. www.ricksmotorsportselectrics.com
3. www.rmstator.com
- Buda
Re: stators for
22 Jul 2009 08:56
Are the Police parts any diffrent form the standard J motor stuff?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- mraaaaaaaaaa
Re: stators for
22 Jul 2009 09:28
not that I know of.
Thx for them ebay, kinda short on moola right now.
Going to meet someone tonight that has the R6 stator.
He wants $30 for it, his scoot is trashed.
R6 stator for his scoot is 106mm, mine miced out at 107.
At electrosport they show same ohms for the three
combinations. But the R6 in the bike bandit page shows
that there are only 4 coils on it, & mine has 18 sooooooooo,
guess for $30 its worth a shot, just dont want to fry my
rec/reg..
Do You think I should connect load resisters on the three
output wires, to stop a over current condition ?
thx for your replys.
rec/reg..
- mraaaaaaaaaa
Re: stators for
23 Jul 2009 03:34
Just tried to match up a R6, no dice, inside diameter to
big,& bolt holes do not line up.
Oh well, fer $30, it was worth a shot.
Hmmm, wonder if "Permabond" would hold it in place
at 10 k RPM, :lol:
TC All, & keep da back rubber down !!
at 10 k RPM, :lol:
