77 kz1000 solid state update
- katman
20 Jul 2009 23:50 #308368
by katman
Vancouver, Canada
www.robwilton.com
s856.photobucket.com/albums/ab127/katman1260/
77 kz1000 solid state update was created by katman
DUUUUUUDES,
NEED HELP!!
Need to loose the speggetti. Want to update to dyna ignition, coils. Also, have to loose the ancient reg/rec for solid state.
I am thinking of using one of my 1982/83 katana 1100 harnesses and system but I have no idea what kind of generator is on these bikes. My kats have three wires(3 phase) kz has 5 wires
Anyone who has done the update please chime in with your wisdom....
cheers,
NEED HELP!!
cheers,
Vancouver, Canada
www.robwilton.com
- loudhvx
- Thank you received: 1616
21 Jul 2009 02:26 - 21 Jul 2009 02:29 #308374
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 77 kz1000 solid state update
What are the 5 wires? I've only seen 3 wires on the 77 KZ1000 alternators. There is also a neutral wire and an oil-pressure wire down there.
Or do you mean the reg/rec wiring?
The 77 KZ 1000 uses a permanent magnet alternator with three phase stator.
The alternator puts out AC on the three wires (usually pink,blue, and yellow or all three yellow).
The rec/reg will need:
three AC input wires (usually all yellow, or pink, blue and yellow),
one 12v output wire (usually red or white),
one ground (usually black or black/yellow, or black/white),
and possibly one sense-wire (brown on most KZ's that have it).
1981 KZ550 D1 gpz.
Other links.
Last edit: 21 Jul 2009 02:29 by loudhvx.
- katman
21 Jul 2009 02:31 - 21 Jul 2009 02:36 #308375
by katman
Vancouver, Canada
www.robwilton.com
Replied by katman on topic 77 kz1000 solid state update
I could be mistaken. I followed the bundle from the sprocket cover and it is a molex plug with 5 wires. My suzuki stator is three yellow into the reg/rec then the r/r has red power and black/wht ground.
ON Suzuki, the blue is neutral and green is oil
IF the z is only the three then I think I may be good to go then?
Thanks for the reply
Vancouver, Canada
www.robwilton.com
Last edit: 21 Jul 2009 02:36 by katman.
- loudhvx
21 Jul 2009 08:09 #308408
by loudhvx
1981 KZ550 D1 gpz.
Other links.
katman wrote:
Yes. The other two in the plug are for neutral and oil.
1981 KZ550 D1 gpz.
Other links.
- MFolks
- Thank you received: 540
21 Jul 2009 11:15 #308425
by MFolks
Replied by MFolks on topic 77 kz1000 solid state update
You might see the side stand switch wiring down there too. I'd trace the wiring before cutting/splicing.
- katman
21 Jul 2009 11:18 #308427
by katman
Vancouver, Canada
www.robwilton.com
Sidestand switch on a '77?
Vancouver, Canada
www.robwilton.com
