1980 kz750 no start only backfire
- Yotaracer4life
19 Jul 2009 16:50 #308077
by Yotaracer4life
1980 kz750 no start only backfire was created by Yotaracer4life
When i try to start the bike all that happens is an occasional backfire while the engine cranks over. If i spray starting fluid in the carbs it will start backfire and then die. I check the splugs and re-gaped / cleaned them and they all spark fine.I have been messing with the carbs only to get nowhere. Any idea on where i should start
- bountyhunter
- Thank you received: 337
19 Jul 2009 17:19 #308082
by bountyhunter
Replied by bountyhunter on topic 1980 kz750 no start only backfire
First thing to check is the timing.
- MFolks
- Thank you received: 540
19 Jul 2009 18:49 #308105
by MFolks
Replied by MFolks on topic 1980 kz750 no start only backfire
Then check where the sparkplug wires are going.
On the Z1, KZ900, KZ1000 and GPZ1100 the left ignition coil wires to the sparkplug #1 and #4 and the right coil go to #2 and #3.
The sparkplug caps can fail intermittently and the mechanical advancer may be sticking.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
19 Jul 2009 19:28 #308118
by 79MKII
The Kaw List:
Replied by 79MKII on topic 1980 kz750 no start only backfire
Make sure coil trigger wires are not switched - that will cause backfire for sure (don't ask how I know)
The Kaw List:
- Yotaracer4life
20 Jul 2009 09:12 #308218
by Yotaracer4life
Replied by Yotaracer4life on topic 1980 kz750 no start only backfire
I know that the wireing is correct for the coils and the spark plugs. it ran fine before and no on has worked on it. and im not to sure of how to check the timing on a motorcycle. how do i know if the camshaft and crank are lined up? do i go by the #1 piston being at tdc and then see where the check the marks behind the ignition control module?
- KOOL RYDER
- KZ 650B2 / KZ 1000E
20 Jul 2009 10:08 #308222
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic 1980 kz750 no start only backfire
Simple question, is your vaccume line from the petcock in good shape? how about your boots from the airbox to the carbs?
If the vaccume line is disconneced or the line is cracked and pulling air, then no gas is getting to the engine (only air)= no start and backfire.
KR
KR
1978 KZ650B
1979 KZ1000ST
- Yotaracer4life
20 Jul 2009 10:35 #308226
by Yotaracer4life
there isnt any vacuum line coming from the petcock there is vacuum ports on the intake boots but they have rubber caps on them the vacuum ports are just there for syncing the carbs i think. and the intake ports are in good shape there arent any cracks anywhere and no leaks.
