1977 KX 650 b1 HOT rectifier
- skydailey
Very Hot Rectifier? Any ideas why?
- skydailey
- MFolks
- Thank you received: 540
To get your battery ready for a load test,fully charge it with a motorcycle battery charger,and then take the battery to the shop, there a tech will put a resistive load across the terminals reading the amount of discharge.
Check the connector going to the regulator/rectifier and see if a small gauge brown wire is in the plug. Some bikes have it others may not. This is the sense circuit for most of the Kawasaki motorcycles limiting the amount of current going to the battery.
The connection may have corrosion in the male/female pins or the brown wire circuit has been damaged.
- bountyhunter
- Thank you received: 337
Yep, I can say with 100% certainty that it is due to power dissipation...... no help, eh?:laugh:Very Hot Rectifier? Any ideas why?
A rectifier only dissipates too much power in two ways:
1) forward conduction (diode on) with too much current going through. The reg will turn the rectifiers ON as much as needed to get the battery up to 14V. Is the battery voltage coming up to 14V? If the batt has a shorted cell, it will cook the rectifiers.
2) OFF STATE (diode blocking) leakage current. A sick, damaged rectifier doesn't turn off completely and has reverse current flow when it should be off and that dissipates HUGE amounts of power because the voltage across it is high then.
- skydailey
- Cychotic
- No sir, I don't like it.
Hope this helps.
1977 KZ650 C1 with '78 C2 motor,
* OEM electronic ignition off '80 KZ750
* 4-into-1 header
* Uni Pod Filters
* #110 main jets, 17.5 pilot jets
1983 Honda V65 Magna stock...sold
1985 Kawasaki Ninja 600R project..sold
1997 Yamaha FZR600...latest toy
- txturbo
- Ex-Kawasaki Mechanic 1981-1985
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
- skydailey
- skydailey
- RonKZ650
- Thank you received: 240
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- bountyhunter
SCR regulators don't bleed off voltage, they act as series switches between the current output coming from the alternator and the battery (and the rest of the electrical system). The voltage at the gates of the SCR's is controlled by the regulator, and this voltage determines if the SCR's are turned ON to pass current. If they are OFF, they block and the alternator output is not connected to anything as long as they are off. Basically, the alternator looks like a big current source and the SCR's are voltage controlled switches that allow the current go to the electrical system as needed to charge the battery and feed the electrical loads of the bike.Yeah the fins are to dissipate the heat as it bleeds off un-needed voltage.
