Flashers' erratic!
- TeK9iNe
- What did you do!?!
Flashers' erratic!
08 Jul 2009 19:21
OK... another problem with my bike. I think I've had just about every prob you could possibly have. Well, I guess I should stop there, so as not to jinx myself... engine is pretty rock solid.
My flashers work fine until the bike gets into higher rpm's, the they no longer blink, and just pretty much stay on solid. As I slow down, the flashers start to blink properly again.
Stator is putting out about 45VAC on each line at 4000rpm. Battery is 1 yr old, holds at 12.37VDC at all times. At 4000rpm, it measures 13.81VDC at 4000rpm and I've never had any charging or power loss problems since I replaced the stator.
Makes me think reg/rect. But everything other than the flashers is ok. OH YEAH, replaced flasher units for signals/hazards in the winter.
? So whats up?
Cheers.
? So whats up?
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
Re: Flashers' erratic!
08 Jul 2009 19:49
When you say flasher, safe to assume you're speaking of "flasher" as in the relay and you've installed L.E.D. technologies?
"replaced flasher units for signals/hazards"
Since your ramping higher in voltage with higher rpm's this is changing your current/load sensing of the relay...
Example: 12Vdc / 2 ohms = 6 amps...
Since resistance (load) is fixed in our bikes, you now have the following in your situation...
~ 13.81Vdc / 2 ohms = 6.9amps
Just in this easy example, you've gained almost 1 amp difference in current draws....
For my LED conversion, I used the following from AutoZone Tridon EP 35... It is designed for Use auto load sensing for LED technologies.
www.tridon.com.au/products/Product.aspx?SG=8&S=35&G=478&P=2000
Maybe it will help....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
09 Jul 2009 01:20 - 09 Jul 2009 01:23
He beat me to it. Sounds like your reg is working right and raising the system voltage up near 14V at higher RPM, which is changing current draw.
Assuming the flasher isn't just blown, the "no flash" syndrome is caused by inadequate current to make the flasher heat up. It can be a blown out turn signal bulb or use of LED lights. If you run LEDs, you should use a solid state flasher unit. Superbrightleds.com sells them.
Last edit: 09 Jul 2009 01:23 by bountyhunter.
- JR
09 Jul 2009 15:37 - 09 Jul 2009 15:37
Oh Boy !
When I saw the title of the post I had to do a double take.
At first glance I saw "Flashers Erotic" and thought WOW !
I must have a filthy mind
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
Last edit: 09 Jul 2009 15:37 by JR.
- TeK9iNe
11 Jul 2009 10:33
Thank you gentlemen! , as usual a plethora of info!
Go KZR members!
LOL! Cheers to that...
Thanks all..
Go KZR members!
Thanks all..
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
