Speedo jumping on acceleration
  • micatpat
  • micatpat's Avatar Topic Author
07 Jul 2009 23:20
#305283
on acceleration the speedo jump's the harder the acceleration the bigger the jumps, at a cruise it has about a 5 mph jump, on a decel it holds the speed steady?:huh: i replaced the cable this spring and probably rode about 500 miles before this started?
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Speedo jumping on acceleration
08 Jul 2009 05:44
#305301
Did you lube the new cable when you installed it? These cables need lube big time. ;)
  • Buda
  • Buda's Avatar
08 Jul 2009 05:54 - 08 Jul 2009 05:54
#305303
Isnt that whats supposed to happen? :huh: :laugh: :woohoo:
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 08 Jul 2009 05:54 by Buda.
  • PLUMMEN
  • PLUMMEN's Avatar
08 Jul 2009 07:00
#305308
is the front wheel staying on the ground? :woohoo: maybe clean up the drive unit on hub while youre at it B)
  • micatpat
08 Jul 2009 08:47
#305391
i did not lube cable, what should i use to lube it? and the wheel is staying on the ground, i would love to say i am good enough to get the front wheel to pick up, and carry;)
  • MFolks
  • MFolks's Avatar
08 Jul 2009 10:55
#305432
Once a year I pull the inner speedo cable out and clean it with sovent,relube it with some moly based wheel bearing grease and reinstall it. No problems!
  • micatpat
12 Jul 2009 20:53
#306643
ok i got it well, i think i did will take it out for a spin tomorow, the speedo cable backed off tightend it up should be good to go
