kz1100 stator need help
- Tedster
04 Jul 2009 05:49 #304310
by Tedster
kz1100 stator need help was created by Tedster
hello
on the kz1100 all the wires coming out of the stator are all the same color,how do you know which ones to plug them into it has to make a difference don't it
Ted
Ted
- bountyhunter
- Thank you received: 337
04 Jul 2009 12:18 #304364
by bountyhunter
Replied by bountyhunter on topic kz1100 stator need help
No, it doesn't make any difference if the unit is good. I believe it is the AC output of a three phase winding so the wire order doesn't matter. If you are ohming them out to check for problems, you may want to mark them so you know what readings went where.
- MFolks
- Thank you received: 540
04 Jul 2009 15:09 #304392
by MFolks
Replied by MFolks on topic kz1100 stator need help
If the wires are all yellow in color, it makes no difference.
Only on the earlier Z1's and KZ900's was phase a concern.
- Tedster
04 Jul 2009 16:59 #304445
by Tedster
Replied by Tedster on topic kz1100 stator need help
all the wires on the original stator and the bike are all white and i can go back out and check but i am pretty sure they are all white with a black stripe,the other cover i got to put on there all yellow,i am gonna probally start a new thread ,now i have another problem i pulled the starter gear off and it s a good thing i did,where the locator or positioning pin that is in the stator cover and goes thru the gears and into the engine case,the casing where the guide pin goes in the block is cracked in two spots,i should post a pic to show what i am talking about,i will take a pic of both stators and wires
Ted
Ted
- Tedster
04 Jul 2009 17:20 #304448
by Tedster
pic of where the guide pingoes thru starter gear into case
- Tedster
04 Jul 2009 17:23 #304449
by Tedster
i can't seem to put these pics on
