ignition switch
- irish mike
- 79 kz 650 b3 rat rod
03 Jul 2009 11:45 #304141
by irish mike
ignition switch was created by irish mike
hi everybody -i just got my new ignition switch for my 79 kz650-previous owner had it hot wired [all wires hanging]i have crimped and butt connected all togeather-all but the 2 white wires-does it matter which white wire connects to which[will i fry any thing by trial and error?]thanks mike.....
- bill_wilcox100
- Thank you received: 5
03 Jul 2009 15:12 - 03 Jul 2009 15:13 #304188
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic ignition switch
Irish Mike, just checked my wiring diagram and the White circuit only has one destination:
To: Ignition Switch main power input terminal.
Then based on the switch position it feeds the Red circuit, the Brown circuit, the Red/Blue circuit and or the 10 Amp Head Light (Blue) circuit.
Re-check your manual, it should say the same thing. If you don't have one... you really need one to save time, money and sanity.
I cooked this up last night for another post:
So two white wires... don't understand?
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 03 Jul 2009 15:13 by bill_wilcox100.
- irish mike
03 Jul 2009 17:27 #304211
by irish mike
Replied by irish mike on topic ignition switch
thanks bill-onthe end of my new ignition switch wires[new switch]there are2two white wires that needto be connected to2 more ihaveevery thing connected but the white ones[2 onthe switch&2on the bike]ihave the same diagram[but thankyou so much 4 taking the time-]i guess since they go to the same 20 amp fuse it shouldnt be a big deal-let me know if you think im f*8*ing up thanks again-i dont know what i would do without kz rider..irish mike....
- bill_wilcox100
03 Jul 2009 18:25 - 03 Jul 2009 18:33 #304223
by bill_wilcox100
Upgrades:
Montreal, Canada
Irish Mike, I'm thinking out loud that the new Ignition Switch assembly in not Kawasaki OEM and therefore likely designed to fit more than one year and model of KZ650. If so, then perhaps one of the White wires is simply not used on our B1 model.
As a work-around this issue have you thought of doing the following:
-1 Disconnect the new switch.
-2 Move the key to OFF position.
-3 Use a multi-meter to buzz out each wire with every other wire.
-4 Record the results on a table.
-5 Move the key to the ON position and record the results on a separate table.
-6 Move the key to the PO position (last position) and record the test results on yet another table.
-7 Identify which "White" circuit, if any, was not switched (not used).
-8 If one "White" circuit was not used then you have found the circuit you don't need and you can ignore it (not connect to it).
-9 On the other hand, if both "White" circuits produce the same results then it does not matter which one you use. In this case use either or both... no problem.
-10 Finally, if the two "White" circuits produce different results... then I'm not sure what you would do at this point... well can't have all the answers you know.
Best of success.
Bill
PS
This is what each of your 3 result tables might look like if it is a 6-pin socket you have. If it were a 4-pin socket then, of course, each of the 3 tables would be 4 x 4 tables. I would put a check mark in the row and column where there was a connection, at a given key position, and empty where there was no connection:
.............c c c c c c
.............o o o o o o
.............l l l l l l
.............u u u u u u
.............r r r r r r
.............1 2 3 4 5 6
Colour 1
Colour 2
Colour 3
Colour 4
Colour 5
Colour 6
Bill
Best of success.
Bill
PS
Colour 1
Colour 2
Colour 3
Colour 4
Colour 5
Colour 6
Bill
Upgrades:
Montreal, Canada
Last edit: 03 Jul 2009 18:33 by bill_wilcox100.
- irish mike
03 Jul 2009 18:59 #304241
by irish mike
thanks bill
