Speedo Cleaning
  • EvanXU1
  • EvanXU1's Avatar Topic Author
Speedo Cleaning
02 Jul 2009 10:11
#303875
1982 KZ 750 Twin. Anyone ever try to open a speedo to clean the inside of the glass? Is there a way to open these suckers?
  • Peterbilt
  • Peterbilt's Avatar
Re: Speedo Cleaning
02 Jul 2009 10:28
#303877
I don't know if the 82 750 has the same style Nippon Densu gauges as my 76 900 but if it does Wired George has a good article on gauge cleaning in the tech stuff index on his web sight. After reading that I took my tach and speedo apart and cleaned both. Took a lot of patients but it looked great when done.
76 KZ 900 A4 Andrews 2x cams V@H exhaust 28mm Mikuni carbs off a KZ1000 rejected with accelerator pump removed and pod filters
  • RonKZ650
  • RonKZ650's Avatar
Re: Speedo Cleaning
02 Jul 2009 11:50
#303892
I have a junk broken Z1 speedo I thought I would practice on, so last night I went to work taking my time slowly prying the ring off. I'll condense the story and say do NOT do it.
  • fixer5000
  • fixer5000's Avatar
Re: Speedo Cleaning
02 Jul 2009 12:20 - 02 Jul 2009 12:28
#303895
ron you musta stabbed your hand at least once!! its easily done if you use a coffee can to hold your speedo or tach. ive done many of them just take your time and dont stab your hands. a little novvus #2 plastic polish works great on the dial faces too. if you really wanna get brave use two teaspoons and pry off the needles using the dial screws as your lever points...be careful here...i did this pair not too long ago and sold it.can you see it was peeled? steve
1978 kz650b pretty much stock
massachusetts
Last edit: 02 Jul 2009 12:28 by fixer5000.
  • fixer5000
Re: Speedo Cleaning
02 Jul 2009 12:29
#303897
back side
massachusetts
