A charging kunundrum
- Titus142
I have a 1982 KZ-750 E2. I can NOT get this thing to charge the battery. Here goes:
New voltage reg/rec from z1
ran new wires everywhere to the ignition switch and back.
replaced almost all other connections.
Took apart can cleaned contacts inside ignition switch.
Tried different battery.
Stator shows no open coils and is outputting about 50V.
Still nothing. Someone sent me a flowchart to check the charging system. Folowing that is says its a bad connection from the switched 12V power from the battery through the ignition switch to the RR. I cant find any more wires and connections to replace.
What am I missing? (oh and the fuse is good too. I checked that as well)
Thanks!
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- keith1
- Thank you received: 2
Have you put a meter on the battery while at idle and about 4000 RPM if so what was the reading?
would second that....donor battery known to be good?...you can clean a crappy ign switch all you want...good luck.....keith
- Titus142
- keith1
at idle its like 12.3 (unless the battery is going dead then its lower) when reved to 4k it will reach about 12.6.
should be 14.5 or so at 4k.....got a good ground on the rr combo from z-1?......donor battery should show 12v across the posts when bike is off....charge batt and let it sit overnite....test it for 12v.....
- Thank you received: 2098
Good Luck!
- Old Man Rock
- Thank you received: 225
Battery current going out, little or none coming back in...
Equates to battery no chargy....
Thus KZ leave you stranded thus you really pissed off...
Equates to you walking, cussing the KZ Gods...
We've all been there, poor/corroded terminations, rust on frame under ground lugs you name it... If you don't have a solid ground to the frame and motor your battery will drain... If you have under rated wire gauge (conductor size) you will not properly charge the battery...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- MFolks
- Thank you received: 540
Three yellow output wires go through a grommet underneath the alternator housing,are gathered with the side stand switch wires,the oil pressure switch wires,and the neutral switch wires in a bundle that runs above and behind the engine sprocket. This bundle runs in a channel as it heads toward the regulator/rectifier electrical plug. To access the wires, the sprocket cover needs to be removed.
There are I believe three bullet connectors for the alternator in this bundle, so one or more may have corrosion or failed.
- Titus142
I have a feeling Ill find something with the ground. Ive completely rewired the positive side of the circuit.
- drkaw
- Titus142
Does anyone know of common problem points that I should check first?
