soledoid CLICK (ground?)
- pburnhamb
01 Jul 2009 06:23
Got the 810 in the frame and thought i had all the electrical junk hiiked up. hit the starter button and the solenoid just clicks. I tried to arc the 2 poles, still no starter. then i tried hooking the jumper right to the starter lug where the cable connects....still no start. Could this be a bad ground, or no ground at all. where should i run the negative bat cable to? the frame or the engine?....
Im good with WrENCHES not wire STRIPPERS.
thanks all.
thanks all.
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- MFolks
Re: soledoid CLICK (ground?)
01 Jul 2009 11:17
What's the battery condition? Have you tried jumping from a known good battery like in a car(non running engine)?
You should fully charge the bike battery, and then have it load tested at a bike shop.
- SQLGuy
01 Jul 2009 11:59
Sounds like the starter itself. The starter gets its ground from being bolted to the case. The battery ground is, of course, that big cable that should be running to the case. The fact that the solenoid clicks, means you're getting at least some ground from the battery. If the ground was bad from the battery, I'd expect the solenoid to chatter.
I'd check the starter brushes.
'82 SECA 750 - converted to fuel injection with Microsquirt and a bunch of home-made pieces.
'83 GPz 750 - mostly stock... so far
Project page: residentialcolorado.com/SECA_750i.htm
- Mark Wing
01 Jul 2009 14:41
Check that the ground wire from the frame to the motor is hooked up. It's near the kick starter on the lower right of the motor.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- pburnhamb
02 Jul 2009 17:15
WOOO HOOOO. ran a new ground to the motor and she fired right up!!! sounds like a bear!!. thanks guys
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- bill_wilcox100
02 Jul 2009 17:28 - 02 Jul 2009 17:29
Congrats.
Now check your other wires and connectors for similar problems... what are the chances that this is the only problem on a 30 + year old bike... don't ask how I know. :blush:
Consider cleaning all connector contacts and adding non-conductive grease found a most auto shops.
Best of success.
Bill
Best of success.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 02 Jul 2009 17:29 by bill_wilcox100.
