- Thank you received: 337
Anybody Try to Dial In a Mechanical Advancer?
- bountyhunter
01 Jul 2009 21:17 - 01 Jul 2009 21:18 #303790
by bountyhunter
Replied by bountyhunter on topic Anybody Try to Dial In a Mechanical Advancer?
I tried the local hardware places, nothing even close. Here are the specs as best I can measure:
COIL DESCRIPTION
total free length 0.9"
coil diameter 7/32 (.218")
wire diameter = .038"
eight coils total, hook ends
material? some kind of hardened steel, VERY stiff
I located some similar coils online at coil companies that don't sell to the public.
COIL DESCRIPTION
Last edit: 01 Jul 2009 21:18 by bountyhunter.
- bountyhunter
01 Jul 2009 21:21 - 01 Jul 2009 21:22 #303791
by bountyhunter
SPARKY47 wrote:
Thanks, I think I will be able to jury rig something up. The ones I have are functional, but definitely screw up the timing. It's either off about ten degrees at idle or at high RPM, or a combination of both. If I set it fast I get good performance and response, but it's cranky to start and sometimes kicks back a little. If I set it back, it is easy to start but it's a little sluggish.
bountyhunter, measure the springs and post it up. Someone must have some spare. I'd let you have a couple but Im in England. But if all fails...just say.
Last edit: 01 Jul 2009 21:22 by bountyhunter.
