tachometer fluctuation kz550
- happyhubby
30 Jun 2009 11:01 #303373
by happyhubby
1980 kz550 daily driver
tachometer fluctuation kz550 was created by happyhubby
my tach fluctuates about 100-250 rpm when idling. what would be a common issue to cause this?
- GPz550D1
- Thank you received: 22
30 Jun 2009 15:20 #303432
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic tachometer fluctuation kz550
If your engine is idling smooth and you feel it is the gauge that not working right, you could try pulling the inner cable out of the tachometer housing and lubricating it. Also, try re-routing the cable if the lube does not help. My tachometer and speedometer jump around quite a bit on my '81 KZ550D1, but not at idle.
Robert
Robert
1981 KZ550-D1
