how to get the best spark for a 81 kz1100
  • ppee
  • ppee's Avatar Topic Author
30 Jun 2009 08:38
#303348
Hi i bought a 81 kz1100 shaft drive two days ago for $400 after replacing a melted earth cable and replacing the oils and filter had it running and idolling beautifully last night. It has a big hole in the balance pipe so that is my next item to do before rego. I reinstalled rear indicators apart from that hadnt touched the wiring yet for some reason appear to have lost spark. The wierd thing is is that all the diagnostic tests i can do seem to be showing up everything is ok ie rectifier/regulator and starter circuits and wiring, i have tried everything time and time again directly from the manual and am going nuts with what to do any help would be appreciated. I read somewhere there was a website that had step by step instructions on how to rewire these older bikes with a relay to help "bring back the spark" does anyone know about this all the other electrics work beautifully and are in great nick i just wish i could get these headaches sorted wich brings me to my last and probly most serious problem and that is the front brakes i tried all day to get dot 8 fluid but couldnt find it anywhere only to be told that dot4 is fine, i then flushed the brakes through and replaced the fluid yet for some reason cant seem to be able to bleed up a good solid lever it is only just and i mean only just grabbing the wheel and that is up on the stand so i would hate to try and stop 250kgs with these brakes. Any help on these issues or reccomendations on exhausts/ helpful websites is greatly appreciated.
  • MFolks
  • MFolks's Avatar
Re: how to get the best spark for a 81 kz1100
30 Jun 2009 10:59
#303372
Go to www.wgcarbs.com His website has all the information about doing the ignition bypass modification using a relay.
  • TexasKZ
  • TexasKZ's Avatar
30 Jun 2009 16:14
#303447
Search the forum for a thread called Soft Front Brake. It has a discussion of air in the brakes. I'll bet there are other similar discussions as well.
  • Kawickrice
  • Kawickrice's Avatar
30 Jun 2009 16:23
#303450
Find out why you lost fire before doing the coil mod. Once you get that right then worry about the mod. Otherwise you could be in for a hair pulling expierence. Just my opinion.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
