82 ltd1000
- brianrae33
28 Jun 2009 15:58 #302825
by brianrae33
1982 kz1000ltd
82 ltd1000 was created by brianrae33
asking this question here because i'm fairly certain my problem is electrical...anyway..drops a cylinde intermitently while riding..sometimes it's great and some..then i can hear a change in idle and will backfire on decel...now..when this cylinder dropping happens..if a crack it wide open it will sputter a bit then catch and take the f$%k off..have cleaned carbs very well..although will do again..and tank is perfect inside..thinking a plug wire..has accel 8.8mm suppresion wires..thinking maybe the carbon strip that runs thru them is bed..any thoughts??
1982 kz1000ltd
- 9am53
- homebrew, and some bbq
- Thank you received: 3
28 Jun 2009 16:25 #302829
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic 82 ltd1000
I am by no means an expert, but I think the copper core wires would be more suited to your bike.
'84 GPz900r
'71 CB350
- kpier998
- Thank you received: 1
28 Jun 2009 20:00 #302884
by kpier998
Replied by kpier998 on topic 82 ltd1000
People more knowledgeable than me say don't use suppression wires with resistor spark plugs. Use one or the other for providing the resistance. I have had some similar problems to what you describe when doing so.
Some spark plug caps have resistors built into them and I believe the 82 model had this. It looked like a small pellet or pill when you take the cap apart.
If you are using the original plug caps, then I suggest that you don't use the resistor wires. Also, the little resistor pellet sometimes gets burned up and causes problems. It would be worthwhile to check them.
So, you could theoretically have resistor plugs, resistor wires, and resistor caps. This would definitely not be optimal.
Good luck!
Good luck!
- brianrae33
30 Jun 2009 07:31 #303330
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic 82 ltd1000
currenmtly has accel wires on it with normal caps..but these wires were on it when i bought it so who nows how old they are..being it's only one cylinder dropping and very intermitant..hoping new plugs and wires solves it..most of the time runs great..
1982 kz1000ltd
- grumpy56
- Thank you received: 6
30 Jun 2009 13:05 #303403
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Replied by grumpy56 on topic 82 ltd1000
Also check your coil connections as one of mine was loose and I experienced the same problem as you describe.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- MFolks
- Thank you received: 540
30 Jun 2009 14:22 #303414
by MFolks
Replied by MFolks on topic 82 ltd1000
The spark plug caps can and do fail, so a new set should help along with new spark plug wires/leads (or for the Brits, the high tension leads).
