HID LIGHTS!!! WHO HAS THEM!
- Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Royal1MC
- Is it just me, or is it just great to be on a KZ
Free shipping in the USA
They work good......brighten up things at night
I went with 6000k....close enough to factory without having issues with the police.
Set up was easy to install
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- Royal1MC
kzrider.com/index.php?option=com_kunena&...d=4&id=192997#196740
Los Angeles, CA
- Silver Tiger
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- otakar
www.xenonlink.com/H4+Hi%25252FLo+HID+Kit...orcycle+HID+Kit.html
Ditto Got the same thing on mine. I also installed the correct reflector to go with it. They do not work as well with the stock lens, where the refractors are in the lens. You wan to get one that has the clear lens and uses a faceted mirror, and also has a bulb cap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Darkangel
Where do you find lenses like that? That uses a faceted mirror, and also has a bulb cap.
- otakar
Otakar,
To find the lens for the bulb is not hard and not expensive. the problem is that they are all set up for cars and do not have the mounting points and cross beam adjusting bracket. I do those modifications my self. I machine out the top and bottom screw points and attach them with a carbon filed epoxy compound and same for the adjuster. By the time I am done it is about the same price as a stock OEM replacement reflector. About $125.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Darkangel
