Still toying with alternator
- iambinjieu
I have a 3 phase stator and electromagnetic field coil on my 77 KZ 650. Not charging, so I've been trying to get to the root of the problem. After much gnashing of teeth, rewiring stator and coil, and troubleshooting, I discovered the following:
50-60 VAC from wires A-B, B-C, but A-C producing only 12VAC
1.1 OHMS across A-B, B-C, 0.8 across A-B
R/R AC inputs diode check yielded a short across one input
SOOOOO. . . what I did until I can finance replacing stator and R/R was to connect the two good phases to the two good diodes inputs and left the bad leads unconnected. VOILA,
14.47 VDC to the battery @ 4K.
Having a Dyna S ignition draws alot of current, so when I turn on the headlight, voltage drops below 13. Been riding all day without headlights on and bike seems happy. Gonna find rrewinder for the stator and ordering a new R/R.
Any comments, prior like findings or otherwise appreciated,
RICK
77KZ650 w/ Dyna S, mildly chopped
81 BMW r65
91 BMW k100rs 4v
- MFolks
- Thank you received: 540
www.rmstator.com
www.electrosport.com
www.customrewind.com
www.regulatorrectifier.com
www.rickssportselectrics.com
- iambinjieu
I appreciate the info you gave me several weeks ago about stator rewinders. Been too busy looking for gainful employment so I can afford to get the stator worked on. Been riding with the three phase running on only two for a couple weeks now, and haven't had to charge the battery once. I still run without headlights during the day, and stay home at night or at least within a couple miles from the house. You seem to be a man with theight answers. I am not worthy. Thanks again,
RICK
81 BMW r65
91 BMW k100rs 4v
- MFolks
Another website to visit is at www.wgcarbs.com He has a similar forum for questions and answers.
- bountyhunter
- Thank you received: 337
You are running the two good windings and rectifier sets wide open to try to compensate for the lost one. It may survive, depends on how much design margin is built into the system. Maybe not. If you are replacing the rect/reg module anyway, probably doesn't matter.Check this out guys and gals,
- bountyhunter
Wouldn't it be cheaper to get a used one from a used parts supply? I know a few that specialize in old KZ stuff.Gonna find rrewinder for the stator
- iambinjieu
RICK
