kz550 spontaneous light issue
  • bountyhunter
  • bountyhunter's Avatar
Re: kz550 spontaneous light issue
19 Jan 2010 17:22
#343564
polkat wrote:
I also thought ignition switch, and I would suggest that you check the fuse box.
Old fuses just get flaky. Pitch the lot of them and put in new ones.
  • KTA
  • KTA's Avatar
20 Jan 2010 02:57
#343586
Fuses can definitely develop oxidation or corrosion on the inside over time which will increase resistance drastically.
Make sure EVERYTHING at the fuse box is clean and corrosion free. Take some sandpaper and rough up the fuse tangs a little bit to clean them. Even if it isn't the problem, it's good to do once in a while.
  • loudhvx
  • loudhvx's Avatar
20 Jan 2010 09:38
#343608
The 82 550 C3 diagram does have some differences. The headlight uses the reserve lighting unit. The front turn signals are also used as running lights. But the ignition switch and fuse layout are basically the same as on the 80 550 A diagram.
There's a chance the reserve lighting unit is bad, but I don't think that should affect the tail/gauges/marker lights.
