Possible Speedo Issue
  • DoubleL3
  • DoubleL3's Avatar Topic Author
26 Jun 2009 10:04
#302223
I believe that either the speedo or tach or both are off. Does anybody know a good way to check if they good? and if they arent reading true a way about getting them to read true?
Thanks
P.S. i have a 1981 KZ550A
  • MFolks
  • MFolks's Avatar
Re: Possible Speedo Issue
26 Jun 2009 10:29
#302229
Give these guys a call:http://www.z1enterprises.com/reference/ZResto_home.aspx
I've read good things about their work.
  • Russ Jackson
  • Russ Jackson's Avatar
26 Jun 2009 10:37
#302230
Hook up a gps unit and compare. Or have your wife follow ahead at a specified speed....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
  • DoubleL3
28 Jun 2009 09:50
#302700
well i checked my speed on a radar equipped speed limit sign that just got put up... it checked out at 25mph and 35mph so my speedo is good but i went on a small road trip yesterday and as i approached redline the tach needle just started bouncing between 10,000 and 8,000 rpms anybody ever deal with this before?
28 Jun 2009 10:08 - 28 Jun 2009 10:11
#302710
Tach bounce might result from frayed interior tach cable or just need cable disassembly, cleaning and lubing.
If in doubt, replace cable with a new one.
Click here > for Z1E tach cable
Good Luck! :)
Last edit: 28 Jun 2009 10:11 by Patton.
  • GPz550D1
  • GPz550D1's Avatar
28 Jun 2009 11:18 - 28 Jun 2009 17:53
#302720
My '81 KZ550D1 has always had problems with the tach and speedo. They jump around quite a bit and are not very accurate. Even after taking the cables out and lubricating them. I bought a new KZ550 in '81 and I remember those gauges jumped around a little, even when new.
Robert
1981 KZ550-D1
Last edit: 28 Jun 2009 17:53 by GPz550D1.
