81 csr 650 front signal lights always on
  • morhaven
  • morhaven's Avatar Topic Author
24 Jun 2009 18:24
#301846
Hi Gents. Question for you
I have an 81 kz csr h1 650cc. I noticed when I turn the key to on both signal lights in the front stay on. just light the headlight. I can use the signals fines. Was it normal for this bike to have these lights stay on?
  • sabell
  • sabell's Avatar
Re: 81 csr 650 front signal lights always on
24 Jun 2009 18:27
#301848
They are running lights, just like on your car.
'78 KZ1000A2
'79 650SR
  • morhaven
24 Jun 2009 19:00
#301864
thanks.. Odd never noticed that on my other bikes.. should all bikes do this?
  • MFolks
  • MFolks's Avatar
24 Jun 2009 19:23
#301871
Depends on the years, most Kawasaki's of the era had dual filiment bulbs in the front for added visibility. Not sure when it was dropped.
24 Jun 2009 19:58 - 24 Jun 2009 20:01
#301879
According to the FSM wiring diagrams, the 1977 KZ1000 carried over the single filament front turn signal bulbs. And the 1978 KZ1000 has dual filament bulbs for combined front turn signal and running light.
I don't know about the 650's, whether they started out with single filament, and if so, when they changed to dual filament.
Good Luck! :)
Last edit: 24 Jun 2009 20:01 by Patton.
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
24 Jun 2009 20:14
#301881
My '82 650 CSR has dual filament front amber lights - running lights are on all the time the switch is on, plus brighter flashing turn signal lights when switched left or right.
The rear amber lights are normally off, except when serving as flashing turn signal lights. I believe the '81 is the same.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
24 Jun 2009 21:49
#301898
If for any reason wanting to disable the running light function, may go into headlight shell and unplug the running light wire to each turn signal, leaving the other blinker wire attached.
Good Luck! :)
