dyna ign
  • eddiem
  • eddiem's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #63
dyna ign
22 Jun 2009 21:17
#301476
my bike has the dyna with the box and two pickups? I guess you would call them pickups?
they use two screws on each to mount them one has been broke where the screws go though.
I'd like to use the other dyna setup that doesn't use the box like mine am I right?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Re: dyna ign
22 Jun 2009 21:27 - 22 Jun 2009 21:29
#301479
The Dyna-S does not have a box. It is a self-contained electronic ignition.
Requires switched 12 volts (red wire).
KZ650 also has blue wire to oil pressure sending unit.
Good Luck! :)
[Click on image to enlarge view]
Last edit: 22 Jun 2009 21:29 by Patton.
Re: dyna ign
22 Jun 2009 21:35
#301482
  • eddiem
Re: dyna ign
22 Jun 2009 21:39
#301485
Thankz Patton
the coils that I have now will work to? they are the green ones
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: dyna ign
22 Jun 2009 21:40 - 22 Jun 2009 21:45
#301486
eddiem, this is what it can look like installed on a '77 KZ650-B1. As mentioned, see the Blue/Red Oil Pressure indicator wire found on KZ650's.
It would help if you put your year, model and location in your signature... and it's considered real friendly too.
For more details see here on how I did mine.
Link
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 22 Jun 2009 21:45 by bill_wilcox100.
  • eddiem
Re: dyna ign
22 Jun 2009 21:43
#301487
Thankz Bill...I really like the idea of no box it gets in the way when I pull the carbs.
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • timebomb33
  • timebomb33's Avatar
Re: dyna ign
22 Jun 2009 21:45
#301488
the one you have is called a dyna 111 the one your looking at getting is called the dyna s it is a self contained unit.
I THINK MY POWERBAND BROKE
Re: dyna ign
22 Jun 2009 21:45
#301489
eddiem wrote:
...the coils that I have now will work to? they are the green ones
Yes, the green Dyna 3 ohm coils will work just fine.
Good Luck! :)
  • eddiem
Re: dyna ign
22 Jun 2009 21:48
#301490
Ok B) I will order it.
Thankz Patton...Time
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Old Man Rock
  • Old Man Rock's Avatar
Re: dyna ign
25 Jun 2009 05:16 - 25 Jun 2009 05:19
#301927
just in case.... As I did my KZ900 guide and issues with images... This is for Dyna installation & Static timing...
Once completed then further align pickup sensors if required with timing light...
OMR
members.cox.net/ruinsofstei/Dyna%20S%20D...ation%20by%20OMR.pdf
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 25 Jun 2009 05:19 by Old Man Rock.
