78' kz 650sr ignition issues
- tugmonkey77
22 Jun 2009 11:21 #301355
by tugmonkey77
78' kz 650sr ignition issues was created by tugmonkey77
:huh: HELP!!!!!! I just finished re-building my 78' 650sr top to bottom. I re-wired and replace all bad or almost bad parts. I triple checked everything! But when I started her the 1st time she was only running on cylinders 2 and 4. so I tried static timing but got no juice to 1 and 4. I then went back over everything and tucked her in for the night. The next morning there was only juice to 1 and 4. 2 and 3 were out. I have done every test on cylinders, coils, regulator and everything else i can think of. I got some iffy reading on the regulator but don't know if that would give me this issue. She's hot to hit the road please, any advice is extremely welcome!
- MFolks
- Thank you received: 540
22 Jun 2009 11:33 #301356
by MFolks
Replied by MFolks on topic 78' kz 650sr ignition issues
Are you running points? If so check the insulators around the springs for shorting.Has the capacitors been replaced lately?
- timebomb33
- Thank you received: 10
22 Jun 2009 11:36 #301357
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 78' kz 650sr ignition issues
pull the plug caps off and check those if they are stock they should be 5kohm resistance caps.
- tugmonkey77
22 Jun 2009 11:44 #301361
by tugmonkey77
Replied by tugmonkey77 on topic 78' kz 650sr ignition issues
the points and capacitors are brand new.
- Cychotic
- No sir, I don't like it.
22 Jun 2009 13:52 #301393
by Cychotic
1977 KZ650 C1 with '78 C2 motor,
* OEM electronic ignition off '80 KZ750
* 4-into-1 header
* Uni Pod Filters
* #110 main jets, 17.5 pilot jets
1983 Honda V65 Magna stock...sold
1985 Kawasaki Ninja 600R project..sold
1997 Yamaha FZR600...latest toy
Replied by Cychotic on topic 78' kz 650sr ignition issues
You could try pulling the caps and trimming 1/4" off the insulation. Also, the regulator regulates the amount of current to your charging system, so it is not the source of your problem. Check the yellow wire w/red stripe to the 2&3 coil for power.
* 4-into-1 header
* Uni Pod Filters
