stator wire configuration?
- kzmason
11 Mar 2006 11:50
I am redoing the wiring from the plug to the stator/neutral switch/oil pressure switch because the insulation on all the wires was brittle and cracking. My problem is that I, stupidly, forgot to make a not of which stator coil wire goes to which (yellow, pink, lite blue) plug wire. Could some one tell me which is which on the pics.
- loudhvx
Re: stator wire configuration?
11 Mar 2006 16:36
If you are using a modern reg/rect combo unit, the order of the colors won't matter. If you are using the stock regulator, the color order may be very important.
Either way, it would be best to keep it in the same order as stock if you can. Sorry I don't know the order. The wiring diagram doesn't show it.
Next time you have the stator off and the camera handy, can you do me a big favor and snap a closeup photo of the rotor (sort of a general angle from above, not straight on.)? I'd like to see what the magnets look like and how many there are. Your camera seems to take pretty good photos.
Post edited by: loudhvx, at: 2006/03/11 19:38
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kzmason
12 Mar 2006 14:57
I'll post a pic before I put it back together. Until I get this question answered I am stuck.
- kzmason
19 Mar 2006 13:12
Well, I had to bribe stator sellers on ebay to finally get the answer. In case anyone else ever needs the info; pink=lone wire, sky blue=non-insulated of two twisted together, yellow=insulated of two twisted together.
and here are the rotor pics I promised
Post edited by: kzmason, at: 2006/03/19 16:14
- loudhvx
19 Mar 2006 18:28
Glad you got it figured out! Hope it didn't cost too much
Those pics look beautiful!
Thanks a million
Thanks a million
1981 KZ550 D1 gpz.
Other links.
Other links.
- kzmason
19 Mar 2006 22:16
Didn't end up costing anything. Someone felt sorry for me and sent the info without the $$.
- loudhvx
19 Mar 2006 22:44
Nice.
1981 KZ550 D1 gpz.
Other links.
Other links.
