coil mod
  • toad
  • toad's Avatar Topic Author
coil mod
20 Jun 2009 17:57
#300953
ok I did the coil mod and my battery read 12 volts when the key isnt on but when I turn the key on my battery and coils (dyna 3 ohm) are only reading around 8 and a half volts and my bike wont start with the starter button.If I kick start the bike my coils read 12 volts can someone please give me an idea thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • TexasKZ
  • TexasKZ's Avatar
Re: coil mod
20 Jun 2009 18:54
#300967
FSM says a fully charged battery should read 13.0 - 13.5 volts.
  • timebomb33
  • timebomb33's Avatar
Re: coil mod
20 Jun 2009 18:57
#300968
sounds like you may need a new battery
I THINK MY POWERBAND BROKE
Re: coil mod
20 Jun 2009 20:11
#300984
Would remove battery.
If needed, bring fluid levels up with distilled water.
Charge overnight (2 amps max).
Specific gravity test (little floating balls).
If doubtful, have battery load tested.
If tests okay, reinstall, being sure of clean snug terminal connections.
And also assure good solid ground connection where negative battery cable attaches to engine.
Good Luck! :)
  • toad
Re: coil mod
21 Jun 2009 05:12
#301028
Ooops:huh:
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
