Will coils interchange ?
  • glassman
  • glassman's Avatar Topic Author
11 Mar 2006 05:24
#30056
I just purchased a 77 kz100 that needs coils there are none on the bike! I have a extra set from my kz650 !
Will stock kz650 work on a stock kz1000?
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: Will coils interchange ?
11 Mar 2006 07:00
#30080
maybe...
it depends on the years.
Kawasaki switched resistance on coils a few times. The coils on points bikes usually read around 3.5 - 3.7 ohm, with electronic ignition setups some are around 1.5 ohm, others 2.2 ohm.
You can use a higher resistance coil that what's on your bike, although you will lose a little spark intensity. You should not use a coil that's a lower resistance - the coils will overheat and eventually fail.
Post edited by: jeff.saunders, at: 2006/03/11 15:25
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • loudhvx
  • loudhvx's Avatar
11 Mar 2006 11:12
#30123
Like Jeff said.
If your 650 coils are for points, then it should work.
