1982 GPz750 Ignition question
- motorpsycho67
19 Jun 2009 02:34
Hey everyone, FNG here. I tried a search for the information and didn't come up with exactly what I need, so here goes...
Does the Dyna-S ignition eliminate the need for the stock IC Igniter? If not, can I graft an igniter from a ZR7S onto my GPz?
My GPz has been sitting for 3 years and I'm dying to get back on it. Help!
Oh, I also need to rering it. Anything I should know that the manual doesn't mention. Parts availability?
Thanks
Thanks
- loudhvx
Re: 1982 GPz750 Ignition question
19 Jun 2009 04:13
The Dyna S is stand-alone. It doesn't use any seperate igniter box. It has all of the electronics built into the timing-plate unit.
The Dyna III (older model Dyna ignition) used a seperate igniter box.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Mcdroid
- Gone Kwackers
19 Jun 2009 06:40
motorpsycho67 wrote:
What is wrong with the stock electronic ignition?
Which manual do you have? If you have the Kawasaki shop manual for the KZ750, then you have the best available manual. Rings are still available through Kawasaki (order then through www.z1enterprises.com as they will be cheaper then through your local Kawasaki dealer).
Thanks
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- motorpsycho67
19 Jun 2009 08:07
Great, that's what I wanted to know.
So the Dyna-S replaces both the pulse coil and IC Igniter.
Also, can anyone tell me how many ohms the stock ign. coils are?
- MFolks
19 Jun 2009 08:09
2.8 to 3.0 OHMS for the stock coils. The Dyna Green coils are also 3 OHMS.
- motorpsycho67
19 Jun 2009 08:20
MFolks wrote:
Huh, I just popped over to the Z1 Ent. site and they say that the 2.2 ohm coils would be the stock equivalent.
- MFolks
19 Jun 2009 09:17
You can go up in coil resistance with a slight loss of energy but not down as the coils will burn out because they run hotter.
- motorpsycho67
19 Jun 2009 12:07
MFolks wrote:
Thanks, I'm aware of that.
