starter solenoid???????
- jbrewer73
Thanks in advance for all of your input.
- MFolks
- Thank you received: 540
- jbrewer73
Or will I need a hole new control?
Thanks for your input
- MFolks
Sounds like some wires got crossed and shorted out the start button.
- jbrewer73
Before I go looking for a switch is there anything else it can be? I can't think of anything. All else is fine.
Is it possible I damaged my elec ignition?
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
You can use acetone (carb or brake cleaner spray) squirted onto a Q-tip to clean contacts.If you can clean up the contacts with some fine sandpaper(400-600 grit) and then use a good contact spray cleaner(Not WD-40!!)
- bountyhunter
The elec ignition should have nothing to do with activating the starter, but it's possible to burn a set of contacts in the ignition switch if the current that smoked the fuse went through the switch.I tried cleaning the contacts but no luck.
- jbrewer73
A buddy had an extra control, so we swapped the switch and that fixed it and I got to keep the switch for no charge.
So big thanks to all.
