KZ1000P Possible Power Loss Issue
- mcdirtnap
15 Jun 2009 16:19 #299434
by mcdirtnap
KZ1000P Possible Power Loss Issue was created by mcdirtnap
Hello fellow motorists, I am a new owner of a 93 kz1000p. I've had it about 2 weeks and put a little over 1000 miles and no problems until yesterday. I would take my hand off the throttle and it would not coast as usual, but lose almost all its coasting power and almost stop and also sometimes it would delay a little bit when I would get on the throttle. Then there was a huge backfire and it went completely dead. I tested the battery and it had plenty of power. It does not turn over. No lights go on, not even the head light, but the emergency lights work. Any ideas as to what the problem may be? The odometer clams to have 28k miles, but I am under the impression it is 128k. I am a very amateur mechanic and just purchased the clymer manual. Any help is much appreciated, thanks.
Joe
Joe
- Old Man Rock
- Thank you received: 225
15 Jun 2009 16:34 #299438
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic KZ1000P Possible Power Loss Issue
I will safely state you have other fuses in that bike... Start there.
The back fire could have been something as simple that since you were driving down the road the power (fuse opened) and since the pistons where still pumping it back fired on you...
First things first, check your fuses and get your power back... Hell my 1976 has 3 main fuses and yours being 1993, you'll have more no doubt....
Chances are this is all you'll have to contend with....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MFolks
- Thank you received: 540
15 Jun 2009 17:01 #299444
by MFolks
Replied by MFolks on topic KZ1000P Possible Power Loss Issue
When these bikes were sold, a lot of wiring was hacked off to remove lights,sirens,radio's and other equipment.
I'd start by opening up the headlight housing and see if any wires are loose/shorting. Trouble shooting will be a hair pulling experiance at best.
- mcdirtnap
15 Jun 2009 19:57 #299495
by mcdirtnap
Replied by mcdirtnap on topic KZ1000P Possible Power Loss Issue
I checked the fuses and they appeared to look ok. The second day I owned the bike I had the front fairing taken off and replaced with just a head light and signals at hollywood motors (wouldnt recommend going there). So my only guess is something with the electrical systems under the seat. There are a lot of loose wires where other equipment was previous connected. Should I just start re-wiring the bike??
- timebomb33
- Thank you received: 10
15 Jun 2009 20:14 #299502
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ1000P Possible Power Loss Issue
find the problem first before you start making decisions like that.
