- Thank you received: 3
running 2 x 6V headlights in series?
- 9am53
- homebrew, and some bbq
15 Jun 2009 11:34 #299385
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
running 2 x 6V headlights in series? was created by 9am53
Hi, I like the look of the FatBob dual headlight setup and I was wondering if I could rig a set of 2x6 volt lights from smaller bikes together in seies as a dual headlight setup. I have a 12 volt light, but it's not on yet, so before I do any mounting I would like to know about the 6 volt lights. Thanks
'84 GPz900r
'71 CB350
- bountyhunter
- Thank you received: 337
15 Jun 2009 14:29 #299413
by bountyhunter
Replied by bountyhunter on topic running 2 x 6V headlights in series?
If you can find 6V headlights, you can wire them in series and run off 12V.
- 9am53
16 Jun 2009 06:13 #299585
by 9am53
'84 GPz900r
'71 CB350
Replied by 9am53 on topic running 2 x 6V headlights in series?
cool, thanks. I found a few on ebay from small (<200cc) bikes, just wondering if anyone else has done it, or if there were any issues with doing it.
'84 GPz900r
'71 CB350
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
17 Jun 2009 06:49 #299859
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic running 2 x 6V headlights in series?
9am, just keep in mind that if you burn out one beam in one light you will lose the second beam as well since they are wired in series. Of course, it'll be no different than losing, say, low beam on a single 12 volt lamp setup.
Just a thought....
Just a thought....
- 9am53
18 Jun 2009 17:30 #300406
by 9am53
'84 GPz900r
'71 CB350
you have a point. I am going to stick with the 12 volt lamp I have, then go to the HD dealer and look at how the fatbob is setup...ie. if there are any failsafes I can include when I hook it up...unless they just have 2 small 12 volt lights in parallel, that would make more sense...but do they make 12 volt headlights that are half the diameter of regular ones?
'84 GPz900r
'71 CB350
- MFolks
- Thank you received: 540
18 Jun 2009 17:56 #300417
by MFolks
Replied by MFolks on topic running 2 x 6V headlights in series?
Both Dennis Kirk
www.denniskirk.com
and JP Cycles
www.jpcycles.com
carry a lot of HD related lights.
- 9am53
18 Jun 2009 18:42 #300430
by 9am53
'84 GPz900r
'71 CB350
thx
'84 GPz900r
'71 CB350
