wiring diagram 74z1
  • kaw74z1
  • kaw74z1's Avatar Topic Author
  • 0 to 60 in 15 minutes.
wiring diagram 74z1
13 Jun 2009 22:59 - 14 Jun 2009 06:03
#298966
Hi,I gotta problem and I need some help. :( I have moved my battery down to my swing arm and my wiring harness is bad So what I need is some of you guys to plz draw me up a wiring diagram with the color of wires that I should use :) All I want is the bike to charge and have a head light tail and brake light and of course a power switch. I will wire my shifter and tach. along with other doodads at a later time. Ohh and the bike is a 74 Z1 with a MKII engine. Thanks
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Last edit: 14 Jun 2009 06:03 by kaw74z1.
  • kaw74z1
Re: wiring diagram 74z1
14 Jun 2009 06:51
#299005
Bump
  • PLUMMEN
  • PLUMMEN's Avatar
14 Jun 2009 07:21
#299016
im no good at drawing things on a computer but if you can get your hands on a shop manual for a kz1000 there should be a mkII wiring diagragm im the back to show the charging system wiring,the rest of it is basically power and ground wires for whatever you add B)
  • Old Man Rock
  • Old Man Rock's Avatar
14 Jun 2009 08:08 - 14 Jun 2009 08:09
#299038
Just extend (longer Battery + (RED) & -(Black) wiring the original connections... Use at least 6-8awg conductor size, preferably 4awg for charging current.
In other words, if you only moved the battery then all that truly changed was the battery terminations...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 14 Jun 2009 08:09 by Old Man Rock.
  • kaw74z1
14 Jun 2009 08:30
#299050
The diagram helps But I need one for a 1979 MKII motor, What I did was remove the complete harness It was butchered up pretty bad Then I removed the battery box and built one on the swing arm, I also built a aluminum plate and mounted it where the inner fender was so I could mount my electrical doodads B) If anyone is good at pc drawing I would be very thankful to just have what I mentioned at the beginning of the thread. Thanks PLUMMEN and Dave you too :)
  • Old Man Rock
14 Jun 2009 08:39 - 14 Jun 2009 08:46
#299053
Ah, I see....
Same time, I wouldn't think there's really that much of a difference for the motor actually has few electrical connections other than dyno/stator, starter motor, ignition plate, oil pressure sending and ground.
Maybe I missed one or so little terminations but that's really about it that are actually connected to the motor itself...
Unfortunately, I don't have the MKII wiring schematic sorry... I'll see if I can hunt one down for you and I'll post accordingly.
OMR
EDIT: Just remembered Tony (moderator) has that same bike... PM and I bet he'll have the wiring diagram for you...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 14 Jun 2009 08:46 by Old Man Rock.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
14 Jun 2009 09:42
#299065
I was just going to say the same thing.
Tony has the same bike and I think he will have the diagram.
1977 KZ1000 A-1
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
14 Jun 2009 09:53 - 14 Jun 2009 09:53
#299066
If you check the filebase on this site you'll find a wiring diagram for a KZ1000A4...it is from the Kawasaki shop manual that covers the MKII motors (1979 and 1980). In that manual, there is not a wiring diagram for the 1979A3 or A3A but there is one for the 1980 A4 model. This suggests that Kawasaki supplied the A4 diagram to cover both years of the MKII production...so if you trust this line of reasoning, you already have access to the MKII diagram... :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 14 Jun 2009 09:53 by Mcdroid.
