- Thank you received: 1
Stator swap
- spudbudy
- Kick it like you mean it
13 Jun 2009 14:09 #298879
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Stator swap was created by spudbudy
Hi gang anybody no if I can swap out my 2 wire stator on a 78 650 for a 3 wire stator off of a 750? I know I will have to get different regulator to handle the 3 phase.
- MFolks
- Thank you received: 540
13 Jun 2009 14:49 #298882
by MFolks
Replied by MFolks on topic Stator swap
I'd look at the filebase here, and I think some one posted how to do it at
a few months ago.
- spudbudy
16 Jun 2009 16:25 #299703
by spudbudy
Replied by spudbudy on topic Stator swap
thanks I will look into that.
- loudhvx
- Thank you received: 1616
17 Jun 2009 01:59 #299831
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Stator swap
Electrically, it can work. If your 2-wire stator has 12 "spokes", and the 750 stator has 18 "spokes", the rotor probably has the right number of poles.
The real question is physical mounting and fit. Obviously you don't want the stator scraping the rotor, and you want the alignment to be the same as with the old stator.
1981 KZ550 D1 gpz.
Other links.
- spudbudy
17 Jun 2009 18:05 #300009
by spudbudy
Yes I'm hopeful that it will fit if not I'm trying to get a rotor to match the newer stator. should be relatively easy to wire up.
- Old Man Rock
- Thank you received: 225
18 Jun 2009 05:54 #300168
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Stator swap
OK, have to ask the dumb ass question of the day...
Why not just get a Dyno/stator designed for the KZ650?
Meaning you have to take a chance on the wiring frying other components, work maybe,/maybe not, swap rectifier/regulators do all this work for what... the price of brand new ~ $120 stator...
I don't get it.... :S
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- spudbudy
21 Jun 2009 16:16 #301142
by spudbudy
No problem this bike hasn't charged right for many years I have replaced the battery regulator stator and rotor several times same exact condition.So I am going to upgrade the charging system to a bigger and hopefully better one. The stock 2 wire stator is kinda weak anyway. I have read that other bikes out there charge just fine my bike is the exception to the rule.
- spudbudy
22 Jun 2009 17:58 #301425
by spudbudy
Got my 750 stator and rotor in the mail today exact same
size as the 650 imagine that. this is gonna be easy.
