Ignition problem
- Davestradamus
Ignition problem
13 Jun 2009 10:56
I finally got my 77 kz650b on the road I have put close to 500 miles on it without any issues.
Here's the problem:
Last night it rained on the bike while I was working. After, I noticed the headlight wasn't working either. I rode it home and it was fine aside from the headlight. This morning I decided to get a bulb for the light to see if it would help. About 10 miles into the journey the engine died. I pulled the clutch and hit the starter but nothing happened. The key does nothing. No lights on the dash or running lights. I have a dyna electronic ignition so I can't kick her either. Help!
Where do I start? I have a diagram. Multimeter?
Thanks!
David
Here's the problem:
Thanks!
David
- Kawickrice
Re: Ignition problem
13 Jun 2009 11:06
Check your fuse box for a blown fuse. Then you need to track down the short. I would start with the wires in the headlight first to make sure wires aren't scraped or nicked
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Old Man Rock
13 Jun 2009 11:10
Battery to fuse to ignition switch. Switch output to the rest of the electronics....
Simple visual of the fuses/DVM voltage measurements will tell all....
Based on your depiction of event / occurrence, Kawickrice hit it on the nose, blown fuse would be my guess as well.
Most likely since you mentioned rained, water leakage to +12Vdc equates to fuse blowing....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
