electric start issue
  • asevans
  • asevans's Avatar Topic Author
13 Jun 2009 09:13
#298810
kz900. i have a problem with electric starter. when i hit the start button i hear a little crackling noise just for a second down at the starter, then all my lights go out. i can try to kick start it a few times, mess around with stuff. turn the key off then on, then sometimes all the lights come back on. it will start with the kick start. and runs fine. it does this sometimes and sometimes it just starts right up. any ideas anybody. thanx
1976 kz900 Mostly stock
1978 Z1-R Project
  • Kawickrice
  • Kawickrice's Avatar
Re: electric start issue
13 Jun 2009 09:21
#298813
Check your battery connections, Sounds like a loose connection or a short. Also check the wires in the headlight sometimes they get chaffed up and short out. Also trace the wires from your right handlebar switch to where they plug in under the tank and make sure all connections are good
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • asevans
13 Jun 2009 18:38
#298924
thanx ill look at the wiring. thats what i kinda figured just didnt know if maybe my starter was going bad. it seems like an electrical issue
1978 Z1-R Project
  • Vter Bob
  • Vter Bob's Avatar
13 Jun 2009 19:13
#298932
Also check the connections at the starter solenoid and at the starter motor.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • edspring1
  • edspring1's Avatar
13 Jun 2009 20:39 - 13 Jun 2009 20:43
#298951
Just my 2 cents on the issue.
NEVER over look anything electrical on these old bkes. BUT to make things a little faster and maybe easier for you. If you can isolate the crackling sound your hearing, go directly to that sound. A bad connection, {worn brushes included} will and do make a sizzling/crackling sound. If your hearing that at the starter it may be nothing more than the battery cable connection is loose. It may also be that the armature or brushes are worn past spec and making a bad connection. Pay attention to your nose also....LOL Usually you can smell a sizzling/crackling bad connection.
Some friendly advice here.
Once a month or so look over your wiring. Specifically look for hard cracked insulation. Its a problem that most of the older Kaws have. Also look over all your connections includeing the fuses and relays. And do not forget to look the grounds over as well. I have found for some reason threw out the years it seems previous owners like to remove ground wires? Since I have started doing this as part of my maintance schedule I have suffered no type of electracl break downs. And more importantly I have had to replace harness's, wire ends here and there. So obviously catching something like this early is a big plus. I have found that lots of people simply overlook the wiring, UNTIL something doesn't work, or melts down...LOL
Once you get your starting problem figured out, look over your entire electrical system. Pull the covers, headlight, even your switches and check under the rear fender. A good electrical contact cleaner and lube goes a long way for preventative maintance. You'll be surprised at what you may find. Your a lot better off repairing any problems on YOUR time, other than something melting down and then you have no choice.
Hope all goes well !
Last edit: 13 Jun 2009 20:43 by edspring1.
  • MFolks
  • MFolks's Avatar
13 Jun 2009 21:06
#298955
A place people seldom check is the alternator grommet where the wires come out of the engine. The insulation may rub or fail there shorting out the alternator and/or causing the regulator/rectifier to fail too.
Another place to look is above the engine sprocket. The side stand switch,oil pressure switch, and neutral switch wires run along with the alternator output wiring in a channel.
Vibration,heat and age can cause any of these wires to short out. They can give intermittant operation if the conductor has been broken inside the insulation but looks good externally.
  • asevans
15 Jun 2009 19:10
#299487
alright, thanks guys.i have done alot to this bike.havent messed with the starter though. i guess im going to learn.
1978 Z1-R Project
