battery tender short??
- brianpclarke
10 Jun 2009 18:00 #298143
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
battery tender short?? was created by brianpclarke
Hey guys,
I was wondering if you guys could help me troubleshoot. This is for my 76 kz900. I have the battery tender "pigtails" hooked up to the battery, so that its a quick connect and disconnect, however sometimes the battery just dies on me. First noticed it when raining, then tried today and it was as dead as a doornail. Wondering if since the ground on the pigtail is exposed, this could be my problem.
Have yet to check out the rectifier, but will do that shortly.
Thanks!
Thanks!
-Brian
1977 KZ650C
1976 Kz900 LTD
- MFolks
- Thank you received: 540
10 Jun 2009 18:14 #298149
by MFolks
Replied by MFolks on topic battery tender short??
I'd think if the pigtail had a short, You'd see a lot of smoke and/or fire. Most bike batteries are 16 amp/hour ratings, I think it would do a simulation of a welder if there was a short circuit.
I suspect your battery is dying and won't hold a charge.
Fully charge it and have it load tested at the bike shop.
