Can I repair my plug cap or do I need a new one?
- chrispysaki
06 Jun 2009 21:17
So, like a total bonehead, I ripped the spark plug cap off the ignition coil wire from my 1980 KZ750E. There is a black coated wire hanging out about a half-inch from the end of the coil wire, but I don't see how I could reconnect it without cutting up the rubber housing.
Does anyone know if there is a way to repair the wire/cap, or do I need to buy a new wire. If I need a new wire/cap, can someone point me to a good place to buy one, and can I buy just one, or do I need to get all four?
Thanks,
Chris
Thanks,
Chris
- MFolks
Re: Can I repair my plug cap or do I need a new one?
06 Jun 2009 21:50
Check with
www.z1enterprises.com
They sell NGK sparkplug wire/lead splices. Is the sparkplug cable/wire/lead replaceable or is it glued to the coil?
- timebomb33
06 Jun 2009 22:33
the plug caps just thread on what i normally do is cut back about 1/4" or so until i get nice fresh wire exposed and then screw it back on the rubber coating if it gets in the way it is ok to cut it back a bit.
I THINK MY POWERBAND BROKE
- hugo
- '92 Zephyr 750
07 Jun 2009 05:41
You did not rip anything. The cap has a spike that 'screws' into the wire copper core splitting the strands. The set up is rather flimsy, but that's the way it is. "Cut it and screw it" as Timebomb said.
07 Jun 2009 06:02
You may want to post a picture of the problem area so we can be sure about what happened. Ed
- chrispysaki
07 Jun 2009 06:54Attachments:
07 Jun 2009 07:19
You should be able to spread the metal opening on the spark plug cap (so you can insert the wire again), fold the black carbon wire back on the rubber spark plug wire so it will make good contact with the metal park of the spark plug cap, and slide it back into the cap. Then pinch the cap so the metal is tight against the spark plug wire and you should be ok. Ed
- chrispysaki
07 Jun 2009 20:54 - 07 Jun 2009 20:56
Is that little black wire sticking out at the end the electrical connection? I figured there would be a standard copper wire inside, but I couldn't find one.
Last edit: 07 Jun 2009 20:56 by chrispysaki.
- kano
- Not Another Bloody Limey!
07 Jun 2009 20:56
chrispysaki wrote:
yes it is
Is that little black wire with the tiny threads inside the electrical connection? I figured there would be a standard copper wire inside, but I couldn't find one.
yes it is
