- Thank you received: 12
75 Z1-B no spark to the plugs
- oldkaws4ever
- Have no regrets...... You only live once.
04 Jun 2009 16:37 #296348
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
75 Z1-B no spark to the plugs was created by oldkaws4ever
Ok, i think my buddy has to be the luckiest bastard in the world. He scored a 1975 z1b with a wiesco 1075 kit, 29 smoothies, 4 into 1 vance & Hines sidewinder. Problem is the guy he bought it from lost intrest in it when he couldnt get it to fire over. Strangley enough the points plate was off of it. So we started working on it, put the points plate on it, i thought i installed it right, and i thought i gapped the points right, but im not sure now. We put the battery in from my z1, and it fired over nice and strong but it would fire up. I pulled the plugs, and im not getting spark to any of the plugs. Could i have installed the points plates and points wrong? Then we thought the coils were bad, so i swapped them for the green dyna's on mine and same thing happend no spark. Any thoughts?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
- Thank you received: 225
04 Jun 2009 18:19 #296365
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 75 Z1-B no spark to the plugs
First off... sweet find.. He is a lucky bastard.... :laugh:
Coming off the ignition switch you only have a few areas where the problem can truly lie...
1) Is the +12Vdc getting through the switch to the coils/ignition plate?`
If no, trace it back, fuse, bad conductor, broken termination, regulator/charging system etc....
2)Does the starter button rotate the motor?
Assumption is yes but maybe you kicked started it so had to ask...
If yes then the emergency power stop switch most likely not the culprit...
3) +12Vdc present on the coil primaries?
4) If # 3 holds true... Is the engine grounded otherwise sparkies no worky!
This should get you started...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Kawickrice
- Thank you received: 18
04 Jun 2009 18:51 #296369
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic 75 Z1-B no spark to the plugs
My kill switch broke on the inside one time and was not noticeable from the outside, the switch seemed to work. It took some trouble shooting to get it figured out. I never use the kill switch anymore unless an emergency because of this. The parts are old and are a mix of metal and brittle plastic. Trace the wires like OMR suggested and that should get on the right track.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2098
04 Jun 2009 18:54 - 04 Jun 2009 18:55 #296370
by Patton
Replied by Patton on topic 75 Z1-B no spark to the plugs
Last edit: 04 Jun 2009 18:55 by Patton.
- oldkaws4ever
04 Jun 2009 18:58 #296374
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic 75 Z1-B no spark to the plugs
Ya the lectric start works, and the right handlebar switch is new from jeff @ Z1. Ok, i went out to fool with it for a bit more, and here is what i found. The coils arent getting any power. The Battery cables are nasty looking, maby my problem lies there. I will have anothe lok tommorow after i get off work.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
04 Jun 2009 20:11 - 04 Jun 2009 20:12 #296399
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Ahhhhhhhhhhh... This should be a no brainer then.....
If the starter is receiving the +Vdc (you need to measure to confirm if +12Vdc) to turn the starter motor then this informs you the off switch is operational...
Again... Measure this voltage for it just may not be ideal value....
Then one other little in line connector between these two points... See RED BOX!
You can perform a continuity measurements between the RED conductor on the emergency or starter switch to either one of the RED coil feeds and this would confirm if you have a open conductor line....
You're almost there.... I think you'll be surprised tomorrow and inform us this old girl kicked over....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 04 Jun 2009 20:12 by Old Man Rock.
- oldkaws4ever
04 Jun 2009 21:02 #296410
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
I know this sounds domb, but since the points plat was off and in a box, i have sneeking suspision that the guy screwed witht he points and the plate to no end. How should it look when its mounted?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
04 Jun 2009 21:55 #296421
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
I just got off the phone with my buddy, he said he was going throught the boxes of parts he got for the bike, he found a brand new in the box dyna-s ignition. So i will through that in tommorow and hope for the best.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
05 Jun 2009 04:53 #296454
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Well you should see +12Vdc (charged battery of course) on the primaries regardless of the ignition plate.
Same +12Vdc on the starter and stop switch conductor that feeds the primaries...
As for the EI setup.... no doubt.... Once static & timed in via timing light don;t have to mess with it again. And for those that wish to advance or retard the timing, simple rotate the plate a little... pretty damn straight forward...
Keep us posted....
OMR
Keep us posted....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- oldkaws4ever
05 Jun 2009 19:03 #296594
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Well after i tried convincing my friend to ditch the point's set up and hook up the dyna but he was dead set on keeping them. I cleaned the battery cables up, im now getting power to the points and coils, but not from the coils to the plugs. I ordered dynatec copper core wires from jeff at z1, hopefully they will be here monday. Im hoping that will get this beast to fire over. He thought there were dyna plug wires in a pacage that was marked that but it was empty. I have the battery charging now on the battery tender, so i will drop it in monday and hope for the best. I was also looking, were the 2 primary wires (green & black) screw into the top and bottom of the front of the coil are corroted up pretty badly, so tommorow, i will take the coils out and clean those up good. Any ideas on what to use on the inside of the plug towers were the plug wire fit's into? It is nasty looking. Thank's Guy's
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- MFolks
- Thank you received: 540
05 Jun 2009 19:19 #296598
by MFolks
Replied by MFolks on topic 75 Z1-B no spark to the plugs
A Dremel tool at low speed with one of their small steel brushes should be able to clean the crud from the coil towers/ports.
- oldkaws4ever
05 Jun 2009 19:26 #296601
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Than's MFolks i will have a go at it tommorow ith the dremel
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
