Xenon plasma bulb in my z1?
- oldkaws4ever
- Have no regrets...... You only live once.
02 Jun 2009 00:33
When i redid my z1 over the winter, i swapped out the stock headlight to an h4 conversion from Z1 enterprises. Well now i did the h4 conversion, i can take the buld out of the back of my headlight. I have a set of HID color appereance Plasma xenon bulb's, but they are 100/90W. I know that is to much juice for the z1. Are there any Xenon HID bulbs with a lower wattage more towards the origanal wattage? Thanks, Jim
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- CSmith
Re: Xenon plasma bulb in my z1?
02 Jun 2009 07:07
No eBay APP ID and/or Cert ID defined in Kunena configurationInstead of using the imitation Xenon bulbs why not go with a true HID system.
I bought one of these...works great.
Plus they do not draw as much as a 90 or 100W bulb.
75 Z1, 1075cc, Dyna S Ignition, Mikuni RS 34mm, Inverted Forks & Mono Rear Shock.
76 KZ900 LTD Stock
80 KZ750 Dyna Ignition, Kerker pipe
76 KZ900 LTD Stock
