Another Problem...YAY!
  • Darkangel
  • Darkangel's Avatar Topic Author
01 Jun 2009 12:38
#295499
ok...So I am out riding and all of a sudden I turn the corner...the bike is running lean anyway, and she stops....I mean flat out stops on me. One of my friends gives me a jumb with his car, and i am on my way back home. When i get there she is dead again... The starter sound horrible like it's a dead battery, I have got a new stator on the engine...i check the volts on the bat and it's 10Volts...ok enough to at least start the bike right....NO! i dont know what the heck is going on...Before my bike was starting up with no issues after the new stator, and since i removed my speedo and tach, my batt doesn't seem to want to hold a charge.
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Re: Another Problem...YAY!
01 Jun 2009 12:59 - 01 Jun 2009 13:05
#295502
Would assure good ground connection where negative battery cable attaches to engine.
Assure battery fluid levels are correct.
Charge battery overnight, input 2 amps or less.
Start engine. Test charging system by measuring voltage across battery terminals. Look for 12+ volts at idle and 14+ volts at 3000-4000 rpm.
Faulty regulator may cause overcharging and loss of battery fluid.
Faulty rectifier may prevent charging. Faulty alternator (aka stator aka generator) may also prevent charging.
Loose connectors into or from a component may prevent the component from working properly. Such as in wiring between alternator and rectifier, etc.
Good Luck! :)
Last edit: 01 Jun 2009 13:05 by Patton.
  • Locozuna
  • Locozuna's Avatar
01 Jun 2009 16:27
#295544
Did ya jump the bike with the car running?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • timebomb33
  • timebomb33's Avatar
01 Jun 2009 16:52
#295551
your ignition system probably wont even fire properly with that low of volts you let alone crank the starter over properly sounds to me like you still have a charging problem to deal with.
I THINK MY POWERBAND BROKE
