- Thank you received: 6
Keep blowing out headlights
- fordtruck
What do think is happening to my headlights? Could my regulator be failing and spiking sometimes?
'77 KZ1000-MTC 1075 kit. Stage 1 port
- MFolks
- Thank you received: 540
I'd remove the headlight and look inside the housing for signs orf wires rubbing and shorting. Also check the fuses and fuse clips for corrosion.The glass tubes fuses can fail or become intermittant.
- fordtruck
For the money I've put out already, I'm really thinking about using one of the conversion kits that uses an H-4 bulb. It's getting old taking everything apart to replace the headlight.
- RonKZ650
- Thank you received: 240
- KawiConvert
- Thank you received: 4
One thing to check, do you have the stock rubber headlight mounts? Its been mentioned before if the headlights don't have some kind of rubber mounts that it's possible to vibrate them until they break. Mine have very small rubber mounts and I can make about 700-800 miles before one will let go again.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- Russ Jackson
- Thank you received: 1
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- Jack
- Thank you received: 7
Check your voltage regulator - if you find you are cooking the water out of the battery as Russ suggested you check, that will blow headlights for sure.Check your Battery water level. Make sure your headlight housing is tight and not moving around and loose....Russ
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Locozuna
700-800 miles between headlights? That would drive me nutz! I haven't replaced a headlight in.....damn I can't remember replacing one! I either got a #1 case of Al Zimer's Syndrome or I got's some sweet lights. You gotta mean 7,000-8,000 miles....right? :huh:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- bountyhunter
- Thank you received: 337
That sounds like a bad reg unit, alternator or battery. The batt voltage should rise to about 14V pretty rapidly when the engine is revving above 3k.I checked voltage at the battery at idle and it was 12.6 and didn't seem to go up much when I brought rpm up to 4k. I unplugged the regulator and plugged it back in and now when I bring rpm up to 4k it slowly starts to come up. It never makes it go 14 volts.
- Sandy
- Fly High,Tony
- Thank you received: 13
I had the same thing going on with MY 77,ans it WAS the grommets(lack of) at the headlight bucket,where the signals tie in.
I was blowing a headlight every other ride out,and after checking all the electrics,I headed to the headlight bucket and put in extra grommets that I made up...never had a problem since,and it's been 3 or 4 years now.
1977 KZ1000 A-1
- fordtruck
It does have the rubber grommets on the headlight mount. I do remember seeing them
- KawiConvert
Nope, so far about 800 on average if it blew out today. I just need to modify the bottom to use some grommets and it will be fine. Just made the mounts too rigid when I welded it up.
