Late model electronic ignition... will it fit on
  • tomcat
  • tomcat's Avatar Topic Author
  • 1977 KZ 1000 Vetter
29 May 2009 15:08
#294861
Late model electronic ignition... will it fit on my 77 model? I wanted to put an electronic iggy on my bike and I was considering a dyna. I saw a couple of places selling the later model stock electronic setup. Will that work on my older model and what would I need if it would?
1977 KZ 1000 Vetter
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: Late model electronic ignition... will it fit on
29 May 2009 15:22 - 29 May 2009 15:32
#294867
tomcat, welcome to the site great to have you here.
Don't know what you have!
If you have a KZ650-B1 like me then the following will fit:
- Dyna S (DS2-2)
- Dyna 3 Ohm Green Coils (DC1-1)
If you would like to see how I installed mine see here:
Link
This is what mine looked like installed:
Notice that I managed to keep my Oil Pressure Sensor wire, Blue/Red Stripe
Best of success. :)
Bill
PS
It would be best if you told us what bike you have. You will notice that many members add their year, model and location to their signatures to get the best responses... and it's considered very friendly too.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 29 May 2009 15:32 by bill_wilcox100.
  • MentalMike
  • MentalMike's Avatar
  • God Bless America!
29 May 2009 18:36
#294912
tomcat - welcome to the site. You've come to the right place for all your KZ needs! The folks on here are always willing to help, so ask away with any questions. :)
Not trying to hijack the thread, but I gotta say thanks Bill for the link to your wireing mods. Great stuff and will no doubt help in diagnosising my electrical issue. :P
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
  • tomcat
29 May 2009 18:36
#294913
1977 KZ 1000 Vetter
I would like to put a latemodel on it because I can get one cheap. Will it work?
1977 KZ 1000 Vetter
29 May 2009 19:26
#294924
This model would work just fine.
Click here >> Dyna-S
Couple of other different model Dyna ignitions are available which would also work just fine.
Good Luck! :)
  • otakar
  • otakar's Avatar
29 May 2009 19:45
#294931
If you want to put something like a 1981 ignition on your 77 it can be done, but you will have to change your coils also to 2.2 Ohm coils. the unit should bolt right on otherwise. If you go with the Dyna ignition you can use your stock coils as long as you keep your ballast resistors or you can go to 3 Ohm coils. The problem you will have with the late Kawasaki ignition is the weiring harness. You will have to make your own. On the Dina it is all included.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • tomcat
30 May 2009 05:04
#294983
are my stock coils fine?
1977 KZ 1000 Vetter
30 May 2009 05:47
#294984
Yes, your stock coils are fine on 1977 KZ1000, which has no ballast resistor. The ballast resistor came with the electronic ignition introduced on the 1979 KZ1000-A3 with igniter and lesser ohm coils.
Good Luck! :)
  • otakar
  • otakar's Avatar
30 May 2009 05:50 - 30 May 2009 05:51
#294985
You'r stock coils are about 1.3 Ohm and the ballast resistor is about 1.5 ohm this makes them together about 2.8 ohms which can be used wit a 3 Ohm ignition (Dyna). Ballast resistors came on all of the points ignitions to prevent arcing. By themselves the coils are not suitable for any ignition I am aware of.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 30 May 2009 05:51 by otakar.
  • otakar
  • otakar's Avatar
30 May 2009 06:00
#294987
I retract my statement. Your coils are 4 Ohm and they are OK for the Dyna however they will give a weaker spark, on the 3 Ohm ignition. Patton is right. MI Bad! :blush:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
30 May 2009 06:06
#294990
Per specifications shown in FSM ---
Primary winding ignition coil resistance on 1977 KZ1000-A1 is 3.2-4.8 ohms. Same for 1978 KZ10000-A2.
Primary winding ignition coil resistance on 1979 KZ1000-A3 is 1.2-1.9 ohms.
Good Luck! :)
  • otakar
  • otakar's Avatar
30 May 2009 06:26 - 30 May 2009 06:29
#294994
What He Said!!!! :silly: :whistle: :blush: Go with the Dina you will be much better off in the long run. The stock Kawasaki ignition is very good if that is what you start out with. To retrofit to it you are over complicating things unless you have other motives. I don't know why but my 78 Z1R came with ballast resistors. They are not even shown in the weiring diagram in the manual.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 30 May 2009 06:29 by otakar.
