- Thank you received: 12
Bike won't start now!
- clutch
- I wish I had a tad more patience to do it better!
1. I may have unplugged a wire I shouldn't have in the harness inside the headlight. Any ideas what to look for there?
2. There is no sound whatsoever when pushing the button, could it be the starter relay?
3. Could it be the neutral safety switch (the wiring that forces you to pull in the clutch lever to start)?
Thanks for any and all input,
Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- clutch
well budd if the only thing you did was change the headlight mount then it only stands to reason that you must have diconected something or pinched a wire check your fuses to see if your getting any power to them make sure the ignition key is turned on when checking.
That's what I was thinking too...already looked for anything noticeable in the harness, but didn't find anything. I was just posting in the hopes that someone would have a specific thing to check for, that maybe had a similar problem...
Wish List:
Z1 (need I...
- clutch
Wish List:
Z1 (need I...
- clutch
Wish List:
Z1 (need I...
- clutch
Wish List:
Z1 (need I...
- MFolks
- Thank you received: 540
- clutch
Check the engine stop switch(the one on the right switch pod)is it disconnected?
Do you mean I should pull that control pod off and check the wiring on it?
Wish List:
Z1 (need I...
- MFolks
- clutch
Wish List:
Z1 (need I...
- clutch
Wish List:
Z1 (need I...
- JR
- Thank you received: 446
Also had a squashed insect smeared across the contacts of the engine run/kill switch which prevented starting.
If you have a clutch lockout switch you should see a black wire coming from the clutch lever area just on the near side of where the clutch cable connects to the lever and if you ever need to remove it go at it from underneath and press in the little black spring tab.
