Dynatek DS2-2
- leorider
23 May 2009 20:02 #293588
by leorider
78 KZ650B
Dynatek DS2-2 was created by leorider
I have a 78 KZ650 B2 with 4 ohm Emgo universal coils I bought on Z1. I recently aquired a Dynatek DS2-2 but I dont have the 3 Ohm coils. Will the Dynatek work with the coils I have now?? What is the worst that can happen if its not compatible?? Thanks!
78 KZ650B
- MFolks
- Thank you received: 540
23 May 2009 20:24 #293591
by MFolks
Replied by MFolks on topic Dynatek DS2-2
My understanding is they will work but with slightly reduced spark energy. I think the system will work best with 3 ohm coils.
I would not get coils with an ohm rating of 2.2 ohms as I understand the coils may be overheated and fail.
- loudhvx
- Thank you received: 1616
23 May 2009 20:55 #293594
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Dynatek DS2-2
You should be fine. The Dyna S wants the minimum resistance to be 3 ohms. Higher is fine.
Since the stock dwell was 180 degrees, and the Dyna's dwell is closer to 360 degrees, there will be more spark energy than the points would give to the 4-ohm coils.
There will potentially be less spark energy than using the 3-ohm coils (as Mfolks said), but more than using the 4-ohm coils with points.
1981 KZ550 D1 gpz.
Other links.
- leorider
23 May 2009 21:04 #293595
by leorider
78 KZ650B
Replied by leorider on topic Dynatek DS2-2
Thanks for the replies guys! I'll go ahead installing it as soon as I find some time.
78 KZ650B
