I keep burning up my cylinder 1/4 coil Update
  • Russ Jackson
  • Topic Author
23 May 2009 16:26 - 07 Jun 2009 14:25 #293535 by Russ Jackson
I keep burning up my cylinder 1/4 coil Update was created by Russ Jackson
First I had an EMGO coil and it stopped working. So I went to the local salvage yard and picked up a used one. Worked fine for 1500 miles. Lately I noticed a strange smell. Thinking it was the seafoam I put in the tank I figured it would go away on the next tank. Well it didnt so I pulled the tank and noticed that the coil had leaked a hard plastic substance out the end. Must have gotten pretty hot. Battery level was low also. Wondering why the 1/4 coil went bad twice and not the 2/3. I am thinking regulator is bad. Any information will help. I will pick up another coil soon and check voltage. Also what year coils will work? Local shops dont carry the old stuff but maybe one of the other years are the same even if the bolt pattern is different....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Last edit: 07 Jun 2009 14:25 by Russ Jackson.
23 May 2009 17:12 #293546 by bountyhunter
Replied by bountyhunter on topic I keep burning up my cylinder 1/4 coil?
Here's what will blow coils:
1) Running a low resistance coil without it's external ballast resistor (if it is intended to use one).
2) System voltage running above 14V.
3) using a high voltage CD ignition with a coil not rated for the higher primary voltage that the CD will put on the coil.
23 May 2009 17:13 #293547 by bountyhunter
Check the system battery voltage with the engine at about 3000 RPM. Sounds like it could be too high with those symptoms.
23 May 2009 17:17 #293549 by Old Man Rock
Replied by Old Man Rock on topic I keep burning up my cylinder 1/4 coil?
Same voltage being applied to both coils so can't see how this would only effect (damage) the 1/4 coils.
Granted, all electronics have associated tolerances of operations but since you've already gone through a coil or two, something else has to be doing the damage...
Since the coils are burning up, I'd start looking for a short to ground on the secondary side of the coils thus excessive current draws being pulled through the coil...
Juts out of curiosity, are you running EI or points/condenser?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
23 May 2009 17:27 #293553 by PLUMMEN
Replied by PLUMMEN on topic I keep burning up my cylinder 1/4 coil?
yeah,what omr said! :laugh:
  • trianglelaguna
23 May 2009 17:35 - 23 May 2009 17:35 #293555 by trianglelaguna
Replied by trianglelaguna on topic I keep burning up my cylinder 1/4 coil?
i had a dyna ignition...and it was burning coils.....the bike came with stock coils from another model(cop bike )i replaced with cop coils theyd work for a bit then burn one...i threaded here and was told my dyna needed 3ohm coils...i bought dyna (green) 3 ohm coils and it went away.....my story......good luck russ
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 23 May 2009 17:35 by trianglelaguna.
23 May 2009 17:49 #293558 by bill_wilcox100
Replied by bill_wilcox100 on topic I keep burning up my cylinder 1/4 coil?
Ditto to all the good advice above and...
I had the same problem when I first got my KZ650.
Long-story-short... the original coil was bad and the used replacement coil was on its way to the same bad. :(
Solution, changed to new coils... problem solved.
Never underestimate an obvious solution. B)
Best of success. :)
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
23 May 2009 18:27 #293563 by Patton
Replied by Patton on topic I keep burning up my cylinder 1/4 coil?
And be sure when the ignition switch is turned OFF that no voltage is reaching either coil.
Good Luck! :)
23 May 2009 18:53 #293570 by jimstan
Replied by jimstan on topic I keep burning up my cylinder 1/4 coil?
And, And Dont let your bike sit to long with the ignition switch on.
"leaked a hard plastic substance out the end"
thats insulation, coil is or will be Kaput (shorted)
  • Russ Jackson
  • Topic Author
23 May 2009 19:06 #293573 by Russ Jackson
Replied by Russ Jackson on topic I keep burning up my cylinder 1/4 coil?
It is a points system. I never leave the ignition on. I think the low water in the battery caused it to continue charging at a higher voltage causing the coil to over heat. I ordered another coil so I can check the voltage...Russ
23 May 2009 19:33 - 23 May 2009 19:47 #293582 by Patton
Russ Jackson wrote:
...EMGO coil...stopped working...used one. Worked fine for 1500 miles...strange smell...coil had leaked a hard plastic substance out the end. Must have gotten pretty hot. Battery level was low also. Wondering why the 1/4 coil went bad twice and not the 2/3. I am thinking regulator is bad....
Sometimes a coil just gets old and dies. It might pass an ohm test with flying colors, then short out a few miles down the road.
Imo, low water in the battery or a failing battery won't cause it to put out more voltage and won't cause the charging system to charge at a higher rate. And poor battery won't cause the coil to over heat. If the regulator fails and allows over 15 volts to the battery, perhaps such high voltage might get beyond the battery to the coil and thereby harm the coil -- but am uncertain of this because the battery usually serves as an electrical "shock absorber" for the system which prevents this sort of thing from happening.
Am thinking the charging system may be tested even with a battery that won't hold a charge. Fill to specs, and assure clean tight terminal connections and where negative ground attaches to engine or frame.
Then start engine and measure voltage across battery terminals. Look for 12+ volts at idle and 14+ volts at 3000rpm. With these figures, charging system is likely okay. Typically less voltage with bad rectifier and more voltage with bad regulator.
If applicable, might consider new combo rec/reg from Z1E.
Good Luck! :)
Last edit: 23 May 2009 19:47 by Patton.
23 May 2009 22:59 #293604 by bountyhunter
A battery losing water is the SYMPTOM, not the cause. The regulator is overcharging it which overheats it and boils the water out and eventually kills it. In that case, the battery is collateral damage and the regulator is the problem.
