Need to know
- Iron Duke
- what are you rebelling against?
Need to know
21 May 2009 22:37
On my last post I recived no reply time is almost up on the listed item, So can anybody tell me will the speedo off a 1980 KZ650 , fit , work , on a 1982 KZ 550 C3 LTD , and if so is it a wiring match ? thanks for the input.
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Need to know
22 May 2009 02:49
They are not the same, quite a bit different actually. The 650 will fit on KZ750 Twins and 900/1000's although the MPH scale will not be correct for the 900/1000. I would look for a correct 550 speedo you see them on ebay often sometimes NOS even. You will have to check the Kaw site to be certain but I believe the 440 LTD and possibly the CSR 305 used the same speedo that you have. Hope this helps.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Iron Duke
Re: Need to know
22 May 2009 09:42
Thanks Gringo will check my other Kawi sites for follow up
1982 KZ550 LTD C-3
