Help! KZ1000B2 Switches w/pics
  • athlonwirez
  • athlonwirez's Avatar Topic Author
21 May 2009 12:41 - 22 May 2009 10:34
#293090
Would it be possible to use the reproduction switches that are sold for the 900's on a 78 1000LTD? They look identical, except for the headlight on/off switch on the right switch assembly.
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
Last edit: 22 May 2009 10:34 by athlonwirez.
  • MFolks
  • MFolks's Avatar
Re: KZ1000B2 Switches
21 May 2009 13:48
#293102
The color codes may not match up but a few minutes with a ohm meter or a self powered test light,and some tape to mark what's what should have you ready to install the switches.
21 May 2009 13:58
#293105
Might need longer harness length for the oem LTD handlebar.
Good Luck! :)
  • athlonwirez
21 May 2009 15:58 - 21 May 2009 15:59
#293125
I also noticed the left side switch does not have the built in hazard button that the LTD does have. :dry:
These are the switches under "Handlebar Switches" on the Redline site if anyone was wondering.
Last edit: 21 May 2009 15:59 by athlonwirez.
  • athlonwirez
22 May 2009 08:36 - 22 May 2009 10:10
#293310
On the electrical diagram HERE ...Does the connections coming off the left hand switch assembly use a bullet type terminal pin to connect to the main wiring harness?
Last edit: 22 May 2009 10:10 by athlonwirez.
  • athlonwirez
22 May 2009 08:39 - 22 May 2009 08:53
#293311
I'm trying to find out if a switch from a 81 650 will work. As far as I can tell the wires all match, same functions, yet the 650 uses a 9 pin connector to attach to the main harness. I'm pretty sure it will work, just not 100%. I would need to get some B1 Male terminals from Z1, correct? The 650 is below.
Last edit: 22 May 2009 08:53 by athlonwirez.
  • MFolks
  • MFolks's Avatar
22 May 2009 08:56
#293316
If you can't get a matching 9 pin connector, you could go to individual bullet style connectors (male and female). I'd use the heatshrinkable crimped butt connectors(splices) for a moisture resistant wire extension if needed.
The following websites have motorcycle electrical connectors:
1. www.easternbeaver.com
2. www.vintageconnections.com
3. www.electricalconnection.com
4. www.z1enterprises.com
  • athlonwirez
22 May 2009 11:32 - 22 May 2009 11:49
#293331
I believe the KZ1000B2 has internal wiring for the handlebars. I wonder if that throws a wrench in the gears for me. I guess the wires pass straight into a hole in the handlebar so no wire is shown. I hate that the bike is one state away while I try to plan on fixing things like this. I suppose the bikes that use external wiring will have the wires exit the switch assembly differently(outside) than the ones with internal wiring(inside, straight into the handlebar)? Anyone know this?
Last edit: 22 May 2009 11:49 by athlonwirez.
  • MFolks
  • MFolks's Avatar
22 May 2009 11:38
#293332
I'm not sure about internal wiring, but if you do have to extend the wires by splicing,stagger the splices so they are not all in one area, making the bundle smaller and easier to pass through the handlebars.
Watch out for internal,sharp metal burrs that will skin the insulation from the wires when you start rewiring.
  • athlonwirez
22 May 2009 12:37 - 22 May 2009 12:50
#293349
Thanks for the tip. Hopefully I will not have to splice. I'm learning a good bit through this; however, if only I could find someone that could just restore the paint on the switches I would not have to worry about wiring at all.
Last edit: 22 May 2009 12:50 by athlonwirez.
