Need: Images of automatic cancel control switch
  • Grebnaws Inc.
  • Grebnaws Inc.'s Avatar Topic Author
19 May 2009 22:02
#292808
I was able to find help soldering my the wires back down but cannot understand how the left hand control switch goes back together. We had to remove everything for access to the 3 wires which had come loose but I can't find a diagram or a parts list to work from.
For those who have seen them, what is the brass roller looking tube for? It looks like a spacer. How many are there supposed to be? I am beginning to think I lost something.
Can anyone explain how the automatic cancellation is supposed to work?
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Need: Images of automatic cancel control switch
20 May 2009 04:38
#292831
Would help if we knew what bike your speaking of here....
PS... Update your profile with year & model number... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Grebnaws Inc.
20 May 2009 08:31
#292862
1983 kz550 ltd. It appeared that the self canceling signal controls were only in use on a few models. Knowing how any of them worked or having a parts diagram would be a big help.
  • bountyhunter
  • bountyhunter's Avatar
20 May 2009 16:07
#292943
The auto cancelling turn signals added to bikes is usually a timer circuit that is wired inline with the power to the turn signal flasher so that when you turn on the signal, it can only flash for a certain length of time and then stops. It resets when you return the TS switch to center.
